Subscribe
Highlighted
Mirror DSS: Could not resize secondary volume
Hi all
I have a really new (Since few hours) OnCommand 5.1 Environment. Now I have some new Warnings in the PM Jobs:
Server_AllDBs_arch: Could not resize secondary volume Nearstore:/Server_AllDBs_arch_mirror_1 (33160) to 363 GB. The new volume size would be less than that of the replica file system
Does someone know why this warning occurs and how to solve this Problem?
TIA
Thomas
Re: Mirror DSS: Could not resize secondary volume
Hi Thomas,
     OCUM 5.1 introduced what is called as Dynamic Secondary Sizing for mirrors.  This is not something to worry and is expected. Take a look at this GSS video to get more info the same.
Looks like you successfully upgraded to 5.1, so did the workaround help you ?
7 Mode Protection Enhancements
Regards
adai
Hi Adai
I know about the DSS feature in 5.1, But the message I see is a warning. Its this warning expected?
The Problem is, that this warning markes my snapcreator Job Status as yellow (normally green). Can I disable this warning (like the "processHostPrimaryAddress" Option)?
I have solved the problem, before you have send me your workaround. So I couldn't test your workaround..
regards
Thomas
Hi Thomas,
     First update of a Mirror connection after the source has shrunk will generate a false error message. In situations where Dynamic Secondary Sizing is enabled for a mirror
relationship and the source volume has shrunk, the next update will generate a secondary re-sizing error message that can be ignored.The update job might will an error for the resize but the mirror job will complete fine.
The error message is generated because Data ONTAP issues an error message stating that secondary resizing cannot happen because the resize is smaller
than the active file system. This error message can be ignored if seen only  once on the first update after the source volume has shrunk. The displayed
message reads as follows:  The new volume size would be less than that of the replica file system.
This issue fixes itself and no backups are lost so no workaround is necessary.
Error Message: myDfmStation: Could not resize secondary volume myFiler:/myVolumeName (10565) to 10.0 GB.
I understand your concern and I think this should instead be made a warning and not an error. BTW I am not going to give you further responses until you add a case for the upgrade issue you raised today
Regards
adai
BTW here is the bugs online link for the same. http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=527011
Regards
adai
Hi Adai
Case is open since 7 hours (Case No. 2004037295) :-)
regards
Thomas
Thanks thomas, Now you will get prompt responses from me
Regards
adai
Hi Adai
Do you have Solution yet for this "little Problem"
regards
Thomas
Hi Adai
I have read a discussion about the hidden option resize_up_only. In my Case set to 1 would be a solution,
Because Mirror Node would not try to make snapmirror destination smaller than the source Volumen (because no resize down happen), correct?
Are there different Sizing Settings for DSS Backup Node and DSS Mirror Node. When yes I could set different Values to avoid the "smaller than" Issue
Regards
Thomas
Hi Thomas,
     The resize_Up_only cant be tuned. Also the DSS for Backup and Mirror Node is controlled by the same option.(dpDynamicSecondarySizing).
As said earlier this message should  go away in your next subsequent update. Are you still seeing the issue ? IF you think this message shouldnt be marked as Warning pls do open a RFE.
Regards
adai
