NetApp Beginner - Help!!!
rksindwani
Hi,
I'm fairly new to NetApps productlines and storage management. I'm looking forward towards a PoC and eying a demo application (probably in Java) with Data ONTAP simulator.
Pls guide and help. A couple of basic and simple operations is what I need to do right now.
1 ACCEPTED SOLUTION
venkat3
hi rish,
Check if you have the httpd options enabled
refer http://communities.netapp.com/thread/2576 see the last comment by kkalyanp_80
hope this helps.
thanks
sr
22 REPLIES 22
venkat3
cool..!!
rish.
Can you please sum it up ..what all changes you did...for the benefit of others.
that would be great
-sr
rksindwani
Sorry for a delayed reply.
Yea, enabling promiscous mode and reboot made the sim running. Besides this, the configurations that you suggest were also done.
