NetApp Beginner - Help!!!
rksindwani
Hi,
I'm fairly new to NetApps productlines and storage management. I'm looking forward towards a PoC and eying a demo application (probably in Java) with Data ONTAP simulator.
Pls guide and help. A couple of basic and simple operations is what I need to do right now.
1 ACCEPTED SOLUTION
venkat3
hi rish,
Check if you have the httpd options enabled
refer http://communities.netapp.com/thread/2576 see the last comment by kkalyanp_80
hope this helps.
thanks
sr
22 REPLIES 22
