NetApp-Harvest install problem
maartendeboer
Hello,
I'ved instaled netapp-harvest-1.2.2.zip and unzip netapp-manageability-sdk-5.3.1.zip at a RHEL 6.6 with
Arch : x86_64
Epoch : 4
Version : 5.10.1
Release : 136.el6
Getting the following error's at test of
# /opt/netapp-harvest/netapp-manager
Can't locate JSON.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /opt/netapp-harvest/netapp-manager line 22.
BEGIN failed--compilation aborted at /opt/netapp-harvest/netapp-manager line 22.
# /opt/netapp-harvest/netapp-worker
Can't locate Time/HiRes.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /opt/netapp-harvest/netapp-worker line 30.
BEGIN failed--compilation aborted at /opt/netapp-harvest/netapp-worker line 30.
Does someone knows how to fix?
Regards, Maarten de Boer.
4 REPLIES 4
olson
Hello your error is indicating you are missing perl packages.
Here are the commands to add via yum.
sudo yum install perl-Time-HiRes
sudo yum install perl-JSON
maartendeboer
Hello Olson,
Thanks for your suggestion.
The 1st worked:
Installed:
perl-Time-HiRes.x86_64 4:1.9721-136.el6
Complete!
The 2nd not:
No package perl-JSON available.
Error: Nothing to do
Any clue. I'm not familiar with those perl installations (yet).
Thanks, Maarten de Boer.
olson
Sorry to hear you are still having issues with this installation.
A complete installation and configuraiton guide was published on the communities site which may be helpful in resolving your issues.
http://community.netapp.com/t5/OnCommand-Storage-Management-Software-Articles-and-Resources/How-to-install-Graphite-and-Grafana/ta-p/109456
maartendeboer
I succeeded by doing (as root);
# yum install cpan
# cpan JSON
Found in http://stackoverflow.com/questions/11753529/install-perl-json-on-centos
