OnCommand 3.1.2 Will not launch
Adam_77
I have a fresh install of OnCommand 3.1.2 on a Windows 7 maching that previously had Chrome installed, but it has since been uninstalled.  I can not launch a fresh install of OnCommand. I receive the below error message, and I can not locate the registrey key or config file to change the default browser.
NetApp OnCommand System Manager
"Unable to launch the browser. Ensure the path 'C:\Program Files (x86)\Google\Chrome\Application\chrome.exe' is correct and try again.'
1 ACCEPTED SOLUTION
SeanHatfield
Is that your %USERPROFILE% or is your profile on another dirve?
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
7 REPLIES 7
Sahana
It can be edited at "SystemManager.config" file present in the folder:
In Win-7 say for Administrator:
C:\Users\Administrator\NetApp\SystemManager\
Refer https://kb.netapp.com/support/index?page=content&id=2022092 (requires login)
Adam_77
Could this be in a different location? I am unable to locate a Netapp folder under /users/administrator/
SeanHatfield
replace "Administrator" in that path with your username.
Adam_77
Of course. Already checked there
Adam_77
SeanHatfield
Adam_77
Recent  had my laptop reimaged. Apparently I now how a roaming profile on a network drive. The netapp folder was there. Thank you for your help.
