Subscribe
Highlighted
Accepted Solution
Oncommand Insight 6.3.2 not able to connect to IBM SVC 2145
we have been trying to add IBM SVC 2145 on Oncammand insight but it keeps failing saying private key not valid. We had generated a new public and private key file, uploaded the public key to the SVC cluster on the oncommand server.
SSH using the same private is working fine for the SVC clsuter and that too from the Oncammand server.
Any recommendations here!
Thanks
Hitesh Thappa
Re: Oncommand Insight 6.3.2 not able to connect to IBM SVC 2145
In the datasource configuration, in the "full path to private key", do you have the filename in that string?
I.e, if your private key file is file.txt
the path needs to be c:\directory\file.txt
Second - what format is the private key in? Is a putty formatted key? If yes, you want to convert it to OpenSSH format with PuttyGEN
Download puttygen, Load the existing key -> Conversion -> Export to OpenSSH
BINGO!! Thank you very much....the conversion fixed the issue.
I have similar (if not the same) issue. I can use the key pair to open putty ssh session, but OnCommand Insight is not working. I tried converting only private key to OpenSSH and then both Putty SSH and Insight did not work. I would appreciate if you someone can shed some light and post detailed steps.
This is the log:
Message:
Can not login to the device using private key:java.io.FileNotFoundException: C:\PUTTY\icat.ppk (The system cannot find the path specified)
Most likely causes:
Key file is invalid
Information in use:
Ip address:10.1.1.226
Private Key File: C:/PUTTY/icat.ppk
What you can try:
Check the private key
Generate key pairs
Confirm connection with alternate SSH client
Thank you
where have you saved the private key? from the error mentioned its seems Oncommand is looking for the private key file in location  C:\PUTTY\icat.ppk but could not find it.
I had a key on web client server. Once I put it on the server where OnCommand was installed, I got another error message:
Message:
scp: /tmp/svc.config.backup.xml: No such file or directory
Thank you
Tarik Hamza | Data Storage Architect | Federal Systems | Data Center Transformation and Outsourcing
Unisys | 11720 Plaza America Drive | Reston, VA 20190 | (O) 703-439-5958 | (C) (202) 415-3635
<http://www.youtube.com/theunisyschannel> <http://www.facebook.com/unisyscorp> <http://www.linkedin.com/companies/unisys> <http://www.twitter.com/unisyscorp> <http://www.unisys.com/>
THIS COMMUNICATION MAY CONTAIN CONFIDENTIAL AND/OR OTHERWISE PROPRIETARY MATERIAL and is thus for use only by the intended recipient. If you received this in error, please contact the sender and delete the e-mail and its attachments from all computers.
ok, did it try to run for some time and then fail, stating the error you mentioend.
It seems the sanscreen could not fetch the svc config backup data....check if you have the svc configuration backed up already.
if not take a config backup and then try running the inventory for SVC again.
You may want to try doubling the timeout value in the datasource. It sounds like SSH is now working, but when the datasource attempted the SCP download of the SVC config file, it wasn't there yet. Doubling the time would give you more time for the SVC config backup to be created and placed in the directory
The issue was that backup config file (xml) did not exist. Once I backed up config, everything was fine. Thank you for suggestions guys. I have never experienced board with such quick replies.
The datasource will tell the SVC to back itself up - you shouldn't have to do it automatically.
The SVC datasource is fairly simple:
OCI SSHs to the SVC
Ask the SVC to generate a fresh backup
Wait
SCP to the SVC, download the xml config backup file
Parse the SVC XML, generate a "odata" XML for OCI Acq to send to the OCI Server
