Operations Manager Storage System Configuration plugin for ONTAP 7.3.1
aman
Folks,
i need some assistance in obtaining the Ops Mgr configuration plugin for ONTAP 7.3.1.
The base ops mgr 3.7 install does not have the plugin zip file distributed by default to install via the “dfm plugin” command.
Each time I try to pull a storage system configuration from ops mgr, I get the following error.
Any help would be greatly appreciated.
Cheers...
Aman Dhillon
Systems Engineer
NetApp
1 ACCEPTED SOLUTION
adaikkap
Hi Aman,
     Generally Plugins for those ONTAP version that are FCSed before the releasse of a particular DFM version is shipped.
Since 7.3 was not FCSed during the release of DFM 3.7, it wasnt.
All ontap plugins for DFM is available on each ontap version download page.(Note: you will need NOW Login)
Below is the link for 7.3.1.
http://now.netapp.com/NOW/download/software/ontap/7.3.1/dfm_plugin.shtml
Regards
adai
3 REPLIES 3
raja
Hi,
Storage System Configuration Plugins for newer versions are availabled on the ONTAP software download page.
http://now.netapp.com/NOW/download/software/ontap/7.3.1.1/
See section "Support for Operations Manager and DataFabric        Manager server multiple-system configurations"
Thanks,
Raj.
adaikkap
Hi Aman,
Regards
adai
aman
Thanks for the replies guys...
found what i needed
