Problems to connect to my Netapps from VPN or a remote office in my company
sandovalic
Hola Folks !
I 'm having serious problems to connect since when we installed the Netapp in 2 office in our company. Normally i need to connect remotly to another machine desktop in the same site of the netapp to enter and use the equipment. I cannot connect using VPN or from my office in another city. This using System Manager 2.0.1, 2.0.2 even 3.0. With SSH i can connect using nas_bmc port.
I will like to know what can we check to solve this issue.
regards,
Daniel Sandoval
System Technologist
Chevron Venezuela
3 REPLIES 3
yannb
As long as you can ping the controller from the VPN, and you can establish a connexion to port 80 or 443 it should be fine
cvincent_ibm
Daniel,
Are you having trouble connecting to another machine via RDP protocol,
or having trouble connecting with System Manager to a NetApp storage device?
Seems like you have two issues?
Charlie
kryan
If you are receiving the error "Permission denied: connect" please see this public report:
http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=626839
