Provisioning doesn't work anymore after adding Disks to an aggregate
brauntvr2swiss
Hi All
Following Problem:
- Two Aggregates (aggr3/aggr4) have increased by adding Disks
- This 2 aggregates (aggr3/aggr4) are member of a Ressourcepool.
- Today We have put a new Qtree in a Dataset which has attached this Ressourcepool. While
  Provisioning want to create a Mirror Volume following "Nonconformant" Error occurs:
-When I remove the 2 aggregates,which have increased (aggr3/aggr4) from the Resourcepool, then Provisioning works without
Problems:
On this Nearstore System I have to add manually a dfpm reslimit after a Ontap Upgrade (8.1.1):
U:\>dfpm reslimit get 1063
Id 1063
ONTAP Version 8.1.1
Product Model FAS3160
Availability None
Maximum number of FlexVols per storage controller
Maximum CPU utilization threshold of storage controller
Maximum Disk utilization threshold of an aggregate
Maximum Deduplication size of a storage system model and ONTAP version (in GB) 51200
Can someone explain me this behaviour....
Thanks a lot and regards
Thomas
14 REPLIES 14
adaikkap
Hi Thomas,
     I think I got you problem. If I understand correctly you are using OCUM 5.0/5.0.1/5.0.2. Traditionally when we want to a create a mirror relations, the destination volume is created to the size of the aggr with guarantee set to none.
I suspect that in your case the aggr3/4 is 64 bit aggr ? Is it so ? If that's the case then the reslimit doesn't have the max size because of which the conformance fails.
Pls follow the workaround in the bug 591117 and also add your case to this bug so that its prioritized to a release sooner.
http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=591117
Also you can avoid this by upgrading to 5.1 where we support Dynamic sizing for Mirror destination volumes as well, where instead of creating aggr sized mirror destination volume we only create it to the size of the source and before every update job check for the source volume size and grow or shrink the destination volume accordingly.
Regards
adai
brauntvr2swiss
Hi Adai
We will upgrade soon to 5.1. We have to test the ha-config-check.exe before upgrade, because its not anymore integrated in DFM and ConfigAdvisor is not yet supportet with metrocluster 😞
Yes this aggregates are 64bit.
Following  the workaround:
1)     Identify the resource limit Id for the ONTAP version and Platform.
      #dfpm reslimit get
2)     From the above output identify the reslimit Id and update the resource
limit of the 64bit de-dupes for that particular platform and ONTAP version
      # dfpm reslimit set <reslimit> maxDedupeSizeInGB=<value>
But I have did this already I think:
Id 1063
ONTAP Version 8.1.1
Availability None
Which correspond with our Nearstoresystem
NetApp Release 8.1.1P1 7-Mode: Tue Aug 21 16:54:32 PDT 2012
Model Name:         FAS3160
And the dedupe Limit from the Documentation is set correct:
FAS3160 ONTAP 8.1.x 50TiB
I dont understand, what is to do know. Have I to increase the dedupelimit from dfpm reslimit to 74.5T (aggr size)?
I have found another hidden option called pmAutomaticSecondaryVolMaxSizeMb. Can I set this temporary to fe 40TB till we upgrade to 5.1?
Greetz and Thanks
Thomas
adaikkap
Hi Thomas,
     Can you set the dedupe limit to 80TB in your case and try this ? The other hidden options will set the max size for all future volumes to be provisioned or re sized to to 40TB.
Regards
adai
brauntvr2swiss
What do you think is the more prober Workaround:
Dedupe Limit to 80TB
or
pmAutomaticSecondaryVolMaxSizeMb to 40TB
or
it doesn't matter
IMHO: My preferred Workaround is the option pmAutomaticSecondaryVolMaxSizeMb
regards
Thomas
adaikkap
Hi Thomas,
     I am still leaning towards Dedupe Limit to 80TB as it only affects the controller of type 3160 and those running 8.1.1 but setting pmAutomaticSecondaryVolMaxSizeMb to 40TB affects all volume resize or creation with protection manger to 40TB.
In fact upgrading to 5.1 will solve all of this.
Regards
adai
brauntvr2swiss
Hi Adai
Now I have tested the dfpm reslimit set, but it doesn't work with this setting (Can't conform Dataset):
U:\>dfpm reslimit set 1063 maxDedupeSizeInGB=81920
Modified resource limit (1063).
Id 1063
ONTAP Version 8.1.1
Availability None
Maximum Deduplication size of a storage system model and ONTAP version (in GB) 81920
With the hidden Option it works:
U:\>dfm options set pmAutomaticSecondaryVolMaxSizeMb=41943040
Changed auto-provisioned secondary volume max size, in megabytes to 41943040.
I think its not a Problem with the dedupe Limit, because the Nonconformant Event say:
"select a size of at most 44.9TB for the new Volume"
This is the size of the aggr before adding Disk and not the dedupe limit of 50TB (defined with dfpm reslimit set)..
I think I leave this hidden option and the next step is upgrading to 5.1..
Thanks for your help and regards
Thomas
adaikkap
Hi Thomas,
     Thanks for your confirmation. So its looks like a different issue. I suggest you to upgrade to 5.1 or when you upgrade revert the hidden or turn it off.Now what makes me think is why is conformance still suggesting the old aggrs capacity and not the new capacity. Also is your source volumes dedupe enabled by any changes ?
Regards
adai
adaikkap
BTW before adding disk was this aggr 64bit or 32 bit ?
Regards
adai
brauntvr2swiss
Hi Adai
Yes Dedupe is enabled and the aggr was from beginning a 64bit aggr...
Which value I have to set for disabling the hidden Value pmAutomaticSecondaryVolMaxSizeMb (disable/off/0).
I wanna test with a temp Dataset without Dedupe to see what happen in this case....
regards
Thomas
brauntvr2swiss
Hi Adai
How to disable the option pmAutomaticSecondaryVolMaxSizeMb, so that PM again makes the Volumes Size=aggr Size?
regards
Thomas
adaikkap
Hi Thomas,
     Pls find below how to disable it.
[root@vmlnx ~]# dfm option set pmAutomaticSecondaryVolMaxSizeMb=0
Changed auto-provisioned secondary volume max size, in megabytes to 0.
[root@vmlnx~]#
Regards
adai
adaikkap
Thomas, BTW can you give me the exact version number like 5.0.1/5.0.2 instead of the build string ?
Regards
adai
adaikkap
Hi Thomas,
     I found the problem you are encountering. You are hitting bug 670808. Pls raise a case.
Regards
adai
brauntvr2swiss
Hi Adai
Thanks for investigating..
In the Moment is OK for us with your Solution:
- dfm options set pmAutomaticSecondaryVolMaxSizeMb=41943040
regards
Thomas
