Slow workflow execution
francoisbnc
I wonder why workflow execution is so slow at the first line of a command 2 minutes in this exemple with WFA 2.2 (same behavior with 2.1 version) without LDAP auth.
11:45:36.381 INFO  [Create volume] ### Command 'Create volume' ###
11:47:12.276 INFO  [Create volume] Executing command: ./Create_volume8173598297431862987.ps1 -AggregateName 'sas_t2_002' -Array '10.139.32.11' -Size '1000' -VolumeGuarantee 'none' -VolumeName 'test'
11:47:12.744 INFO  [Create volume] Get-WfaCredentials -Host 10.139.32.11
11:47:12.900 INFO  [Create volume] Credentials successfully provided for '10.139.32.11'
11:47:13.103 INFO  [Create volume] Connect-NaController (with credentials) -Name 10.139.32.11 -Timeout 60000 -ErrorAction Stop
11:47:24.662 INFO  [Create volume] Connected to controller
11:47:24.927 INFO  [Create volume] Creating a new volume - name 'test' , aggregate name 'sas_t2_002' , size '1000m' , volume guarantee 'none'
11:47:34.147 INFO  [Create volume] Command completed, took 117735 milliseconds
My productive wotkflows take more than 30 minutes just for cloning 5 volumes and mapping luns inside to igroup.
Any suggestions appreciate.
François
1 ACCEPTED SOLUTION
jcbettinelli
Salut François,
We had such kind of issue with SnapManager Service for one of our customer.
There is an option in Internet Explorer called "Check for publisher's certificate revocation". I'm wondering if this option could help as well in your problem.
If this is enable, some programs needs an internet access.
That would be nice if you could give it a try
Cheers,
JC
49 REPLIES 49
jdowning
Aparker is working with me onsite.  We tried the fix but that didn't help.
The import of the modules is quick.
Here is the systeminfo from aparker's VM:
Host Name:
OS Name:                   Microsoftr Windows Serverr 2008 Enterprise
OS Version:                6.0.6002 Service Pack 2 Build 6002
OS Manufacturer:           Microsoft Corporation
OS Configuration:          Standalone Server
OS Build Type:             Multiprocessor Free
Registered Owner:          Windows User
Registered Organization:
Product ID:                55041-381-2247303-76321
Original Install Date:     1/27/2014, 3:38:26 PM
System Boot Time:          2/19/2014, 8:14:06 AM
System Manufacturer:       VMware, Inc.
System Model:              VMware Virtual Platform
System Type:               x64-based PC
Processor(s):              2 Processor(s) Installed.
                           [01]: Intel64 Family 6 Model 29 Stepping 1 GenuineIntel ~2400 Mhz
                           [02]: Intel64 Family 6 Model 29 Stepping 1 GenuineIntel ~2400 Mhz
BIOS Version:              Phoenix Technologies LTD 6.00, 1/15/2013
Windows Directory:         C:\Windows
System Directory:          C:\Windows\system32
Boot Device:               \Device\HarddiskVolume1
System Locale:             en-us;English (United States)
Input Locale:              en-us;English (United States)
Time Zone:                 (GMT-08:00) Pacific Time (US & Canada)
Total Physical Memory:     8,191 MB
Available Physical Memory: 5,887 MB
Page File: Max Size:       16,429 MB
Page File: Available:      13,908 MB
Page File: In Use:         2,521 MB
Page File Location(s):     C:\pagefile.sys
Domain:                    WORKGROUP
Logon Server:
Hotfix(s):                 2 Hotfix(s) Installed.
                           [01]: KB955430
                           [02]: KB968930
Network Card(s):           1 NIC(s) Installed.
                           [01]: Intel(R) PRO/1000 MT Network Connection
                                 Connection Name: Local Area Connection
                                 DHCP Enabled:    No
                                 IP address(es)
aparker
To follow-up on this, we may be seeing some different issues.    What we are seeing at our customer (a major US bank) is that it takes about 5 MINUTES for each WFA command block to start execution.      The server being used is pretty much cut off from the outside world, so I thought it may have had something to do with checking for certificate revocation.     But we tried disabling that by various methods, including as shown in this article:  http://velemental.com/2012/01/01/optimizing-the-execution-of-powershell-and-powercli/
Nothing made a difference.   If we open a powershell window on the server, it seems to open in a normal amount of time.    If we load the ONTAP module, it loads normally and quickly.   So we don't see the issue by using the powershell command window.
Our onsite guy at the customer is going to look into getting the server more outside access or adding it to the domain (which is currently isn't on).
-Alan Parker
sinhaa
Francois, Parker,
     I don't know what else can I suggest you to try. I just can't think of anything as of now.
Maybe you can try to upgrade the WFA server to .NET 4.5 version and if possible to Powershell 3.0 and see if it helps.
-sinhaa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
jdowning
Upgraded to both...still doesn't help.
jdowning
Upgrade to 2008R2 earlier today and our 5 minute wait seemed to have  disappeared.  Not sure what fixed because the upgrade kept all the  settings and it wasn't a clean install.
francoisbnc
Hi sinhaa,
Do you know if some kind of certificates check is used for ONTAP module?
I traced communication during load of module, and process tried to access 50.63.243.228 port 80.
3573          184.174793000          10.140.16.45          50.63.243.228          TCP          66          52724 > http [SYN] Seq=0 Win=8192 Len=0 MSS=1460 WS=256 SACK_PERM=1
Following this fact,  I configured proxy in Server.
11:18:14.316 INFO  [Remove volume] ### Command 'Remove volume' ###
11:18:36.499 INFO  [Remove volume] Executing command: ./Remove_volume6766461420913838121.ps1 -Array '10.139.32.11' -VolumeName 'test'
11:18:36.655 INFO  [Remove volume] Get-WfaCredentials -Host 10.139.32.11
11:18:37.014 INFO  [Remove volume] Credentials successfully provided for '10.139.32.11'
11:18:37.139 INFO  [Remove volume] Connect-NaController (with credentials) -Name 10.139.32.11 -Timeout 60000 -ErrorAction Stop
11:18:42.536 INFO  [Remove volume] Connected to controller
11:18:44.861 INFO  [Remove volume] Removing all volume quotas, volume name: test
Workflow speed is miraculous good now
aparker
How much of a delay did you have before?
-Alan
francoisbnc
2 minutes
Francois
sinhaa
I'm glad it has  finally worked for both of you.
francoisbnc
sinhaa,
The idea was not to configure proxy settings in WFA server, can you tell me more about this unwanted traffic.
francois
sinhaa
Francois,
         Honestly, I don't know the answer right now. I'll post it once I find out.
francoisbnc
Regarding my case engineering opened a new bug for this issue.
http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=802749
francoisbnc
Hi Sinaa,
Was there a change on Netappp side? I have to change to v3.0 because compatibility with ocum 6.2 and the slowdown problem reoccurs, event certificate unchecked.
I tried to play with bug solution 802749 and standalone-full.xml. When I removed lines, the WFA server service won't to start any more.
For HTTP: <connector name="http" protocol="HTTP/1.1" scheme="http" socket-binding="http" executor="http-executor"/>
For HTTPS: <connector name="https" protocol="HTTP/1.1" scheme="https" socket-binding="https" secure="true" executor="http-executor">
François
abhit
Francois:
Thanks for your reply.
Are you still facing the slow execution problem with WFA 3.0?
Regards
Abhi
francoisbnc
Hello abhit,
Yes the problem reappears since ver 3.0, the workaround worked for 2.x version but not works in the last version.
An example for a simple clone take 98 sec to complete., before in 10 sec.
09:36:01.626 INFO [ITS Clone volume on Last Snapshot] ### Command 'ITS Clone volume on Last Snapshot' ### 09:36:03.048 INFO [ITS Clone volume on Last Snapshot] Get-WfaCredentials -Host 10.139.32.75
09:36:03.126 INFO [ITS Clone volume on Last Snapshot] Credentials successfully provided for '10.139.32.75'
09:36:03.235 INFO [ITS Clone volume on Last Snapshot] Connect-NaController (with credentials) -Name 10.139.32.75 -Timeout 60000 -ErrorAction Stop -HTTP 09:36:04.188 INFO [ITS Clone volume on Last Snapshot] Connected to controller 09:36:54.345 INFO [ITS Clone volume on Last Snapshot] Create a clone for Volume sge_fcp_mssql_gdc01467_01 , named sge_fcp_mssql_gdc01840_01_clone
09:37:40.049 INFO [ITS Clone volume on Last Snapshot] Command completed, took 98423 milliseconds
François
abhit
Hi Francois:
Sorry to hear that the issue is reappearing.
We have opened a bug in our tracking system.
The number is 909331.
We have not observed this internally, so we may ask you to share
some more information if we require.
Regards
Abhi
ag
NetApp
Hi Franc,
This is a custom command. Is it possible to provide the custom command? This will help with RCA.
francoisbnc
Hi,
I did some new tests again and it'seems the speed is back to normal now,  probably the FAS6240 has to much activities during the first of test.
WFA is not involved in the slowness.
14:38:48.051 INFO [Clone volume] ### Command 'Clone volume' ### 14:38:49.395 INFO [Clone volume] Using cached controller connection 14:38:51.098 INFO [Clone volume] Create a clone for Volume vol_source , named vol_source_clone 14:38:52.145 INFO [Clone volume] Command completed, took 4094 milliseconds
Apologize, my mistake.
François
sinhaa
Francois,
          I've not tried removing the http-executors in wfa3.0. If that is the case, I'm not sure.
 I can suggest another thing which has worked for some others.
Upgrade your .NET version to 4.5 or later. Then after run the .NET repair tool from here.
http://www.microsoft.com/en-us/download/details.aspx?id=30135
Do it even if the .NET upgrade went fine and didn't throw any errors. Just download the repair tool and run it
sinhaa
francoisbnc
Hello sinhaa,
Yes I did, but after removing this key, I cannot start WFA server service any more.
For .NET I run WFA on W2K12R2 so 4.5 is installed as feature already.
François
francoisbnc
