Slow workflow execution
francoisbnc
I wonder why workflow execution is so slow at the first line of a command 2 minutes in this exemple with WFA 2.2 (same behavior with 2.1 version) without LDAP auth.
11:45:36.381 INFO  [Create volume] ### Command 'Create volume' ###
11:47:12.276 INFO  [Create volume] Executing command: ./Create_volume8173598297431862987.ps1 -AggregateName 'sas_t2_002' -Array '10.139.32.11' -Size '1000' -VolumeGuarantee 'none' -VolumeName 'test'
11:47:12.744 INFO  [Create volume] Get-WfaCredentials -Host 10.139.32.11
11:47:12.900 INFO  [Create volume] Credentials successfully provided for '10.139.32.11'
11:47:13.103 INFO  [Create volume] Connect-NaController (with credentials) -Name 10.139.32.11 -Timeout 60000 -ErrorAction Stop
11:47:24.662 INFO  [Create volume] Connected to controller
11:47:24.927 INFO  [Create volume] Creating a new volume - name 'test' , aggregate name 'sas_t2_002' , size '1000m' , volume guarantee 'none'
11:47:34.147 INFO  [Create volume] Command completed, took 117735 milliseconds
My productive wotkflows take more than 30 minutes just for cloning 5 volumes and mapping luns inside to igroup.
Any suggestions appreciate.
François
1 ACCEPTED SOLUTION
jcbettinelli
Salut François,
We had such kind of issue with SnapManager Service for one of our customer.
There is an option in Internet Explorer called "Check for publisher's certificate revocation". I'm wondering if this option could help as well in your problem.
If this is enable, some programs needs an internet access.
That would be nice if you could give it a try
Cheers,
JC
49 REPLIES 49
