System Manager 2.0 not displaying LUNs on DOT 8.1RC2
steven_jenner
Hi,
Following an upgrade of my FAS3270 from DOT 8.0.2 to 8.1RC2 the System Manager 2.0 GUI no longer displays the LUNs branch (see below) stopping me from administering them via the GUI. As FilerView does not work with DOT 8.1 that leaves only the CLI available for management and creation of LUNs.
Also if I check under the protocols branch I can see NFS and CIFS listed but not iSCSI or FC/FCOE.
The LUNs were all viewable via the System Manager GUI prior to the upgrade, have I missed something??
Thanks in advance for all replies.
1 ACCEPTED SOLUTION
vmsjaak13
Looks like this has been fixed in 2.0R1D1 which was released yesterday: https://now.netapp.com/NOW/download/software/systemmgr_win/2.0R1D1/
Regards,
Niek Baakman
8 REPLIES 8
karthikv
You are hitting the licensing bug on System Manager 2.0R1 for DOT8.1 RC1 and DOT 8.1RC2
https://communities.netapp.com/message/73337#73337
Currently there is no workaround but to use CLI.
We are working on the fix and will be communicated as soon as the fix is ready.
Thanks,
Karthik
steven_jenner
Hi Karthik,
Thanks for the reply, is there any ETA for this fix?
Regards,
Steve.
vmsjaak13
Regards,
Niek Baakman
karthikv
The patch has been published, however the Access a Specific release will not be fully functional for this particular patch (a ticket has been raised and will be resolved soon).
In the meantime, please use these links:
https://now.netapp.com/NOW/download/software/systemmgr_lin/2.0R1D1/
This is a patch release for the licensing issue. It is advised that only those customers who are hitting the above issue install this patch.
Thanks,
Karthik
jjardina_dtech
I have this same bug and those download URLs no longer work.  How can I get the patch???
jjardina_dtech
That did it!  I have applied the patch and it has indeed squashed this bug.
Thanks for the quick response!
steven_jenner
Hi Niek,
I have applied that update adn can confirm that I can now see and create LUNs for my filer running DOT 8.1RC2.
Thanks,
Steve.
