Don't have an account?
I'm unable to add Netapp Storage contoller to WFA tool.... Please check the screenshot below
When i used the same credentials to login either from Putty or Directly from Http i was able to login to the Filer. Can somebody help??
Solved! See The Solution
Mahesh, pleas check "options httpd.admin.enable" on the storage controller. This setting needs to be on
Did you know you can receive a notification when new software releases are published to the NetApp Support Site?
Join our Discord Community
