Volume Capacity Used vs Total graph - Dedupe space savings not shown
cveuskens
When looking for reporting on Deduplication I'm experiencing the following problems:
- Selecting the report "Volume Space Savings - Deduplication......." generates no data.  The notification as show in the screenshot below states that there are no volumes.
- Selecting the report "Volume Capacity Used........" generates a graph, but  Dedupe space savings is not shown on this graph.
1 ACCEPTED SOLUTION
michelvankessel
did you configure a account to connect to the filers? Some information is collected via SNMP, but some info is collected via SSH or RSH  regards Michel
2 REPLIES 2
michelvankessel
agireesh
Do you have a volume with dedupe enabled in your setup. Dedupe report should show the data only if you have volume with dedupe enabled in your setup.
