Volume - QOS (priority queue) view not graphing in Performance Advisor after enabling FlexShare
RBLT_GLOBAL
With FlexShare enabled, and set to non-defaults for 2 of 20 volumes, I have set priority for *all* volumes as per "FlexShare Design and Implementation Guide TR-3459".
I get data on all volumes when I run "stats show priorityqueue" on the filer, however I dont get any graphs in Performance Advisor ( NetApp Management Console ), when historical ( 1 hour ) selected, although I do see graphs when "real time" is selected.
I have restarted DFM services, in case it was needed to refresh the counters.
Comments/suggestions welcome...
OnTap 8.0.1P3 7-Mode
DFM 4.0.2.7803 (4.0.2)
Priority Queue - Data Collection Settings
Performance Advisor - Priority Queue - Historical ( 1 hour )
Performance Advisor - Priority Queue - Real Time
thanks!
Rick
13 REPLIES 13
RBLT_GLOBAL
Looks as though priority counters are enabled and have up to date records on the DFM server, so just need to get them to display in the PA graphs?
C:\Windows\system32>dfm perf data list -o klnas1-1
Counter Group             Host Name                                Oldest Record            Newest Record            Number Records  Used Space      Max Projected Space
system                    klnas1-1                                 Tue Apr 24 12:11:00 2012 Thu Jun 14 16:26:49 2012           72268 20.7 MB         150 MB
disk                      klnas1-1                                 Wed May 23 23:00:02 2012 Thu Jun 14 16:26:49 2012           30240 92.8 MB         92.8 MB
aggregate                 klnas1-1                                 Thu Jun 07 00:39:55 2012 Thu Jun 14 16:27:10 2012           10080 604 KB          604 KB
ifnet                     klnas1-1                                 Thu Jun 07 03:05:41 2012 Thu Jun 14 16:26:51 2012           10080 9.24 MB         9.24 MB
nfsv3                     klnas1-1                                 Tue Apr 24 12:09:54 2012 Thu Jun 14 16:27:10 2012           71272 16.1 MB         16.1 MB
nfsv4                     klnas1-1                                 Tue Apr 24 12:09:25 2012 Thu Jun 14 16:26:51 2012           72539 14.2 MB         102 MB
prisched                  klnas1-1                                 Thu Jun 07 15:56:09 2012 Thu Jun 14 16:26:41 2012           10080 846 KB          846 KB
target                    klnas1-1        0 768 bytes       768 bytes
lun                       klnas1-1        0 768 bytes       768 bytes
volume                    klnas1-1                                 Thu Jun 07 08:23:46 2012 Thu Jun 14 16:27:03 2012           10080 96.2 MB         96.2 MB
cifs                      klnas1-1                                 Tue Apr 24 12:09:50 2012 Thu Jun 14 16:27:32 2012           70949 1.90 MB         14.0 MB
fcp                       klnas1-1                                 Tue Apr 24 12:11:02 2012 Thu Jun 14 16:26:38 2012           70775 4.60 MB         34.1 MB
iscsi                     klnas1-1                                 Tue Apr 24 12:09:44 2012 Thu Jun 14 13:11:56 2012           71640 4.66 MB         4.66 MB
vfiler                    klnas1-1        0 768 bytes       768 bytes
processor                 klnas1-1                                 Tue Apr 24 12:09:26 2012 Thu Jun 14 16:26:46 2012           73458 27.3 MB         195 MB
perf                      klnas1-1                                 Tue Apr 24 12:17:09 2012 Thu Jun 14 16:23:48 2012            7256 3.62 MB         3.62 MB
priorityqueue             klnas1-1                                 Thu Jun 07 15:55:09 2012 Thu Jun 14 16:27:24 2012           10080 30.8 MB         30.8 MB
wafl                      klnas1-1                                 Thu Jun 07 15:05:23 2012 Thu Jun 14 16:27:17 2012           10080 1007 KB         1007 KB
qtree                     klnas1-1        0 768 bytes       768 bytes
adaikkap
Hi Rick,
     Can you try turning on the following options ?
perfAdvisorShowAllViews           Disabled
perfAdvisorShowDiagCounters       Disabled
Regards
adai
RBLT_GLOBAL
Hi Adai,
The options were already enabled.  Real-time view of Volume - QOS ( priority queue ) does display graphs, but Historical ( 1 hour ) does not ( particularly for pq_usr_sched_total and pq_sys_sched_total ).  I wonder if it could be a bug with DFM v4.0.2.7803 (4.0.2)?
C:\Windows\system32>dfm option list |findstr perfAdvisor
perfAdvisorEnabled                    Enabled
perfAdvisorMaxMonitorThreads          32
perfAdvisorPollInterval               5 minutes
perfAdvisorShowAllViews               Enabled
perfAdvisorShowDiagCounters           Enabled
perfAdvisorTransport                  httpsOk
adaikkap
What version of DOT is your controllers running ?
Regards
adai
RBLT_GLOBAL
controllers are running 8.0.1P3 7-Mode
and DFM includes the installed plugin "Storage System Config 8.0.1 (8.0.1P3) - storage systems and vFilers"
adaikkap
Hi Rick,
     Thanks for the details. BTW AFAIK, plugins are not required for PA capability. Only the config managment capability for Filer and vFiler require plugins to mange the options on the controller and some config files.
Regards
adai
RBLT_GLOBAL
Hi Adai,
Thanks for the info on plugins.   This is a simple environment, with four 6210s ( two A/A pairs ), all running the same DOT, only serving NFS at the moment.
I looked at "Performance Settings" settings for Performance Advisor, and wondered if the "Average" radio button in "Computation Type for Views" should be changed to "Maximum".  I found it strange that the radio buttons do not behave as expected, as shown below, the radio buttons "None", "Average" and "Maximum" can be selected simultaneously?
Regards,
Rick
seshu
Rick,
You don't need to change any performance settings, I did try to create a similar custom view choosing the same counters as you have opted for and I can see both the historical and real time data with out any issues.
Moreover I am using Oncommand 5.0 version.
Kindly let me know if we can have a WebEx session to take this issue further to debug?
Regards,
-Seshu
RBLT_GLOBAL
Hi Seshu,
I would appreciate a WebEx.  Does the offer still stand if we are running the IBM N-Series / Management Console?
Regards,
Rick
seshu
Rick,
Let me give a try ..at this moment I can not say what is the difference with N-series as I have never worked on N-series box.
Regards,
-Seshu
adaikkap
Hi Rick,
     N-Series or FAS shouldn't make any difference.  Yes still seshu offer is valid and holds good.
Regards
adai
seshu
Rick,
Let me know your free time tomorrow or any other day for WebEx session, I work in Netapp Bangalore and I am available from 9 AM IST - 10 PM IST.
Regards,
-Seshu
kaikapola
Hi!
Did you find any way to fix this?
I'm trying to to get graphs for FlexShare counters, but NMC is not drawing anything.
//KK
