WFA Create SnapVault for Volumes NOT Qtrees
CHRISTIAN_UMREIN
Hi all,
I'm looking for the command to set up a snapvault between primary volume and secondary volume on 7-Mode systems.
The certified command "Create SnapVault" works only based on Qtrees.
Has anyone already written this command?
Thanks in advance,
Chris
4 REPLIES 4
JGPSHNTAP
In 7-mode snapvault is Only qtree based if you want to manage it via OCUM Protection manager.
If not, you can do vol/ - destination qtree
If you do NOT have any qtrees, you can use /-  to /-
JGPSHNTAP
In addition, in cDOT this has now become volume based with XDP replication, but thats another whole animal at this point
CHRISTIAN_UMREIN
Thanks JGPSHNTAP,
that works for me.
Chris
CHRISTIAN_UMREIN
Hi JGPSHNTAP,
I'm sorry but your suggestion was not the solution for my problem.
In the command "Create SnapVault" I tried to use the finder for "primary qtree".
"Select one Qtree by its natural key"
Qtree Name: '/-'
Array IP: create_nfs_volume_existing_vfiler.array.ip
Volume Name: create_nfs_volume_existing_vfiler.name
Preview check:
Failed to resolve expression 'null'Location: 'Create SnapVault' command > 'SnapVault' tab > 'snapvault_existing_nfs' variable > 'primary_qtree' property
Any idea what's my fault?
Thanks,
Chris
