Hi all, Hope I can find help here configuring my first workflow.
In my network, I have many remote locations, been mirrored or vaulted to one SVM located in the center.
Due to WAN bandwitch and amount of data, there are always some mirrors still running on mornings.
I am trying to build, Or customize the built-in "abort snapmirror relationship" workflow. What I want to do is to let it run on the destination SVM- And Abort all running mirrors.
Problems I run into are:
If I configure the destination cluster and SVM, It will only "see" the first relationship I have, out of many.
If I configure it with Destination volume- How can I do it? Is there a way to use a wildcard search, or somehow configure it run on all relationships?
All clusters are at least 8.2.2 cDOT. no 8.3.X for now.
WFA version 3.1P1
Thank you!!
Itay
