I'm new to WFA so this may be an easy fix that i'm missing.
I intend to upgrade our NetApps to 9.1 GA and read that the DP snapmirrors should be converted to version-flexible (XDP) snapmirrors before doing so. I found a workflow called "Converting SnapMirror Relationship to SnapVault or Version-Flexible Snapmirror Relationship", which is what i'm trying to get working now. However, when I run the workflow, none of the fields populate with any values. I guess I assumed that this workflow would query OCUM database for the Destination Cluster field and then the rest would follow. I have attached a screenshot. What am I missing?
