function for replacer to match small regex
dblackwe
I need to be able to replace a user input with just part of the users input.
In this case it's aggregate selection.  Somewhere in every aggr name is either a1,a2,a3,or a4.  Unfortunatly its not always in the same place.
I was hopeing for something like;
if( inputStr = [a1])
return "a1";
that way Aggr1_a1_oracle_prod and filer2_15k_esx_fcp_a1 would each let me replace them with a1.  This doesn't work, and programing isn't my strong suite.  I have to do something similar for several diparent examples so if a regex match could be shown it would really help me out.  There are at least a hundread aggregates and I dont' want to have to do if/else for all of them.
Thanks
1 ACCEPTED SOLUTION
sinhaa
You can define a function as below and use it in your workflow. Its also ignore case senstivity for A1 and a1 in the aggr names. If you don't want that then remove toLowerCase() from the below and it should be fine.
def getString(str)
import java.lang.*;
if( str.toLowerCase().contains("a1") ) return "a1";
else if ( str.toLowerCase().contains("a2") ) return "a2";
else if ( str.toLowerCase().contains("a3") ) return "a3";
else if ( str.toLowerCase().contains("a4") ) return "a4";
else return str;
sinhaa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
sinhaa
def getString(str)
import java.lang.*;
else return str;
sinhaa
dblackwe
Sinhaa
This worked perfectly.  Thank you so much, again you save the day.
David
