needed tools to design solution and controller
MJABER
hi all ,
is there any tolls from netapp can help me to desgin an solution with Netapp controller including the parts .
i have used synergy but it is showing only the  controller without shwoing hte parts i have use  .i.e. i need tools to provide me with details part report if possible .
Thanks all
2 REPLIES 2
hariprak
Hi,
 Synergy tool  shows the controller as well as Systems: Parts List. Can you please let us know what information are you looking for so that we can help you better.
Could you elaborate?
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
MJABER
hi ,
thanks for your reply .
i have attached the report i got from the the tools regarding the part it is not shwing th IO module i have added to system . all what i can see it the disk , controller and switched .
i am looking for more details including th IO module and cards .
the viso digram generated from the tools does show there is an module but as image  what i need is part details .
Regards
