nfsstat -l doesn't work with other vfliers
Nfsstat_Commad
Hello ,
I'm trying to command vfiler run vfiler_gaia01 nfsstat -l to determine which clients are mounted to this NFS share but it doesn't work
I've also enabled options.nfs.per_client_stats.enable . Tried to run the same command on vfile0  (vfiler run vfiler0 nfsstat -l ) and it worked
Can you please give me some advice how to run command on another vfiler than vfiler0
Kind Regards
Tien
1 ACCEPTED SOLUTION
ekashpureff
Tien -
Looking at the man page - it should work ?
"When run from a vfiler context, (for example, via the vfiler run command), nfsstat operates on the concerned vfiler. Note that if vfilers are licensed when using the -h and -l options it is necessary to run this command from a vfiler context, since the interpretations of the hosts are dependent on the vfiler. "
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff, Sr.
Independent NetApp Consultant http://www.linkedin.com/in/eugenekashpureff
Senior NetApp Instructor, FastLane US http://www.fastlaneus.com/
(P.S. I appreciate 'kudos' on any helpful posts.)
2 REPLIES 2
ekashpureff
Tien -
At your service,
Nfsstat_Commad
Hi Eugene
Thank you for your reply . Yes . We've checked it.
We cannot run the command because of lack of licence .
Kind Regards
Tien
