Hi
I am running OCUM 6.1 (is it supported with harvest 1.3).
I am getting errors bellow
[2016-12-13 16:27:07] [DEBUG ] [connect] Reverse hostname lookup successful. Using HTTP/1.1 for communication.
[2016-12-13 16:27:07] [WARNING] [sysinfo] system-about API failed with reason: Server returned HTTP Error:
[2016-12-13 16:27:07] [WARNING] [main] system-info update failed; will try again in 10 seconds.
I have created username netapp-harvest in OCUM and can login with it.
also when I do curl -k -v https://192.168.1.20/
* Rebuilt URL to: https://192.168.1.20
* Hostname was NOT found in DNS cache
* Trying 192.168.1.20...
* Connected to 192.168.1.20 (192.168.1.20) port 443 (#0)
* successfully set certificate verify locations:
* CAfile: none
CApath: /etc/ssl/certs/
* SSLv3, TLS handshake, Client hello (1):
* SSLv3, TLS handshake, Server hello (2):
* SSLv3, TLS handshake, CERT (11):
* SSLv3, TLS handshake, Server key exchange (12):
* SSLv3, TLS alert, Server hello (2):
* error:14082174:SSL routines:SSL3_CHECK_CERT_AND_ALGORITHM:dh key too small
* Closing connection 0
curl: (35) error:14082174:SSL routines:SSL3_CHECK_CERT_AND_ALGORITHM:dh key too small
this is my netapp-harvest.conf
this is 2 node cluster running 8.2.3 Ontap
[xxxx01]
hostname = 192.168.1.11 (node 1)
group = SS
[xxxx01]
hostname = 192.168.1.12 (node 2)
group = SS
[xxxx21]
hostname = 192.168.1.20
group = uniman
host_type = OCUM
data_update_freq = 900
normalized_xfer = gb_per_sec
