"Create export" command problem
vladimirzhigulin
My WF is 1. create a Vol; 2. Export the Vol.
The WF fails with the following:
Missing an argument for parameter 'Anon'. Specify a parameter of type 'System.String' and try again.
I look at log (i changed IP's, names etc.):
10:10:24.625 INFO  [Create Export] Executing command: ./Create_Export2162464948268547412.ps1 -Anon -Array filer16 -NoSuid $true -Path /export -RWhosts @('','root=<IPs here>') -VolumeName volname
10:10:49.363 INFO  [Create Export] Expression to invoke: Add-NaNfsExport -Persistent -Path /export -ActualPath /vol/volname -NoSuid -Anon -Root @() -ReadOnly @() -ReadWrite @('','root=IPs here)
10:10:49.545 ERROR  [Create Export] Missing an argument for parameter 'Anon'. Specify a parameter of type 'System.String' and try again.
10:10:49.979 ERROR  [Create Export] Missing an argument for parameter 'Anon'. Specify a parameter of type 'System.String' and try again.
10:10:49.993 INFO  [] ***** Workflow Execution Failed *****
So -Anon doesn't have any value, however it has '0' value in appropriate Define FindChart.
Now I look at "Create Export" command:
if ($Anon)
    $expression += " -Anon"
So it seems to me that it should be:
if ($Anon)
    $expression += " -Anon $Anon"
Or am I missing something here?
Vladimir
1 ACCEPTED SOLUTION
tanzim
Hi Vladmir,
Good catch!
This issue is a known issue and has been fixed in subsequent builds.
The relevant logs :
Planner :
06:50:35.900 INFO  [Create Export] ### Command 'Create Export' ###
06:50:37.088 INFO  [Create Export] Executing command: ./Create_Export5845317870079201040.ps1 -Anon 65536 -Array x.x.x.x -VolumeName test_vol
06:50:37.150 INFO  [Create Export] Get-NaCredentials -Host x.x.x.x
06:50:37.275 INFO  [Create Export] Connect-NaController (with credentials) -Name x.x.x.x
06:50:41.447 INFO  [Create Export] Connected to controller
06:50:45.853 INFO  [Create Export] Removing NFS export : /vol/test_vol
06:50:47.275 INFO  [Create Export] Expression to invoke: Add-NaNfsExport -Persistent -Path /vol/test_vol -Anon 65536 -Root @() -ReadOnly @() -ReadWrite @('all-hosts')
06:50:48.744 INFO  [Create Export] Command completed, took 12844 milliseconds
The corresponding fix in the "Create Export" command(as you correctly pointed out) :
if ($Anon)
   $expression += " -Anon " + $Anon
Regards,
Tanzim
6 REPLIES 6
tanzim
Hi Vladmir,
Good catch!
The relevant logs :
Planner :
if ($Anon)
Regards,
Tanzim
vladimirzhigulin
Hi Tanzim,
Indeed your fix works as expected.
There is another issue however 😃
My execution logs (no changes to output whatsoever this time):
13:20:03.678 INFO  [BK -  Create Export] Executing command: ./BK_-__Create_Export6540396713782142586.ps1 -Anon 0 -Array 10.196.68.207 -NoSuid $true -Path /export -RWhosts @('10.196.68.0/24:10.196.69.0/24:10.196.174.0/24') -Roothosts @('10.146.68.45:10.146.68.7') -VolumeName csmail
13:20:04.075 INFO  [BK -  Create Export] Get-NaCredentials -Host 10.196.68.207
13:20:04.188 INFO  [BK -  Create Export] Connect-NaController (with credentials) -Name 10.196.68.207
13:20:26.569 INFO  [BK -  Create Export] Connected to controller
13:20:28.281 INFO  [BK -  Create Export] Expression to invoke: Add-NaNfsExport -Persistent -Path /export -ActualPath /vol/csmail -NoSuid -Anon 0 -Root @('10.146.68.45:10.146.68.7') -ReadOnly @() -ReadWrite @('10.196.68.0/24:10.196.69.0/24:10.196.174.0/24')
13:20:28.707 INFO  [BK -  Create Export] Command completed, took 29049 milliseconds
13:20:28.721 INFO  [] ***** Workflow Execution Completed *****
Now I check /etc/exports on the filer 10.196.68.207:
/vol/csmail     -sec=sys,rw,root=10.146.68.45,nosuid
I don't know what's wrong this time, Add-NaNfsExport  bug?
Vladimir
tanzim
Hi Vladimir,
The follow up issue that you mentioned was quite tricky to debug. I've managed to find the issue and solution.
I found that when i provided values to the input parameters "RootHosts" and "RWhosts" as
          RootHosts:     "root1"
          RWhosts:      "rw1 rw2"
the workflow failed to set anon=0 in the /etc/exports file on ONTAP.
However, when i provided the values as
      RootHosts:     root1
      RWhosts:       rw1,rw2
the workflow successfully set anon=0 in the /etc/exports file on ONTAP.
Please try this out in your setup and let me know if it worked for you.
Logs mentioned below :
FAILED SETTING
11:44:23.348 INFO  [Create Export] ### Command 'Create Export' ###
11:44:24.551 INFO  [Create Export] Executing command: ./Create_Export3238572789650908080.ps1 -Anon 0 -Array 10.68.66.213 -NoSuid $true -Path /test_path9 -RWhosts @('rw1 tw2') -Roothosts @('root1') -VolumeName test_vol9
11:44:24.645 INFO  [Create Export] Get-NaCredentials -Host 10.68.66.213
11:44:24.707 INFO  [Create Export] Connect-NaController (with credentials) -Name 10.68.66.213
11:44:28.473 INFO  [Create Export] Connected to controller
11:44:32.864 INFO  [Create Export] Expression to invoke: Add-NaNfsExport -Persistent -Path /test_path9 -ActualPath /vol/test_vol9 -NoSuid -Anon 0 -Root @('root1') -ReadOnly @() -ReadWrite @('rw1 tw2')
11:44:34.285 INFO  [Create Export] Command completed, took 10937 milliseconds
/etc/exports entry
/vol/test_vol9  -sec=sys,rw,nosuid
SUCCESSFUL SETTING
11:45:35.331 INFO  [Create Export] ### Command 'Create Export' ###
11:45:36.535 INFO  [Create Export] Executing command: ./Create_Export7555570186892756222.ps1 -Anon 0 -Array 10.68.66.213 -NoSuid $true -Path /test_path10 -RWhosts @('rw1','rw2') -Roothosts @('root1') -VolumeName test_vol10
11:45:36.628 INFO  [Create Export] Get-NaCredentials -Host 10.68.66.213
11:45:36.691 INFO  [Create Export] Connect-NaController (with credentials) -Name 10.68.66.213
11:45:40.503 INFO  [Create Export] Connected to controller
11:45:44.753 INFO  [Create Export] Expression to invoke: Add-NaNfsExport -Persistent -Path /test_path10 -ActualPath /vol/test_vol10 -NoSuid -Anon 0 -Root @('root1') -ReadOnly @() -ReadWrite @('rw1','rw2')
11:45:46.019 INFO  [Create Export] Command completed, took 10688 milliseconds
/etc/exports entry
/test_path10-actual=/vol/test_vol10,sec=sys,rw=rw1:rw2,root=root1,anon=0,nosuid
vladimirzhigulin
Hi Tanzin,
Thanks a lot for your help. I can confirm that passing values for both RootHosts and RWhosts as separated by comma in WF works as expected.
Vladimir
fenton
Are you wishing to pass something in the anon definition - if no then this field should be left blank in the define chart for the export
Example below...
vladimirzhigulin
I really needed to have "-Anon 0".
Vladimir
