volume comment for cDOT update and get
scheckel
Hi,
regarding to my powershell threat ( https://communities.netapp.com/thread/33016 ), maybe somendy has already done it.
Can the volume create command expanded with the volume comment?
My customer wants to add a comment with a internal ticket number during the provisioning.
Or can somebody help me with a vol modify command.
Best wishes,
Markus.
1 ACCEPTED SOLUTION
sinhaa
Hi Markus,
      Import the attached command for scheme cm_storage. You can use it to add/modify volume comments. It can be imported on WFA2.1
warm regards,
Abhishek
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
sinhaa
Hi Markus,
warm regards,
Abhishek
scheckel
Thanks Abhishek for the quick help
