OpenStack Discussions
[Folsom] Need help troubleshooting Cinder with NetAppISCSIDriver
BLENTZ_RH
It appears that the bulk of my issues were various settings and configuration issues within openstack itself and had nothing to do with the netapp driver specifically.
1 REPLY 1
bswartz
Brett, your conf file and logs look fine. Can you give an example of the actual CLI commands you typed and where you observed the problem? I'm wondering if maybe your running as an usual user or running a different command than we normally test with.
