Subscribe
Help with conformance
I have a problem with a tenant who has a large quota.
I want them to be able to create as much as 10TB worth of volumes for their project. I've set the quota in openstack as such.
However, when they try to create volumes, these errors appear in the conformance.log
May 17 13:29:29 [dfmserver:ERROR]: [20140:0x7f0455ec1700]: The following task ('Resize flexible volume 'g219828n3270a4001:/OpenStack_bfafccc3f78b4dca877f03fc5aeac75c_1' (1079) by 39.1 GB' (359)) failed for object OpenStack_bfafccc3f78b4dca877f03fc5aeac75c (615).
May 17 13:30:04 [dfmserver:ERROR]: [20140:0x7f0455ec1700]: The following task ('Resize flexible volume 'g219828n3270a4001:/OpenStack_bfafccc3f78b4dca877f03fc5aeac75c_1' (1079) by 30.0 GB' (363)) failed for object OpenStack_bfafccc3f78b4dca877f03fc5aeac75c (615).
According to dfm reports, I have more than enough available space on both my aggrs.
Re: Help with conformance
Hi Abel - let me see if I can help. Can you provide me with a little more detail about the setup of the quotas? What is the output of
nova-manage project quota --project=<project name>
Thanks
Jeff Applewhite
This project has gigabytes: 81920
The SUM(size) from volumes where project_id='this project' and deleted=0 = 13221
So, at least on the nova side, we should be ok
