OpenStack Discussions
How can I attach a volume to VM using netapp volume driver?
JAESANGLEE
Hi, I set my openstack volume driver to NetAppISCSIDriver.
(nova version is essex milestone-1, I think it's too old, but It's not important)
I also configured some flags for driver.
This is my configuration.(nova.conf)
42 ### volume configuration
43 --volume_manager=nova.volume.manager.VolumeManager
45 --volume_driver=nova.volume.netapp.NetAppISCSIDriver
46 --netapp_login=administrator
47 --netapp_password=password
48 --netapp_server_hostname=10.4.1.252
49 --netapp_server_port=8088
50 --netapp_storage_service=Cloud
52 --netapp_wsdl_url=http://10.4.1.252/dfm.wsdl
53 --netapp_storage_service_prefix=cloud-
When I create volume It looks like normal.
~$ nova volume-create 5 --display_name jaesang3 --availability_zone b_zone
~$ nova volume-list
| ID |   Status  |   Display Name  | Size |             Attached to              |
| 35 | available | jaesang3        | 5    | None                                 |
It's value of volumes table.
*************************** 10. row ***************************
         created_at: 2012-11-14 13:07:40
         updated_at: 2012-11-14 13:07:46
         deleted_at: NULL
            deleted: 0
             ec2_id: NULL
            user_id: admin
         project_id: sds_netapp_test
               host: stest4.p18.poc
  availability_zone: b_zone
        instance_id: NULL
         mountpoint: NULL
        attach_time: NULL
             status: available
      attach_status: detached
       scheduled_at: 2012-11-14 13:07:40
        launched_at: 2012-11-14 13:07:46
      terminated_at: NULL
       display_name: jaesang3
display_description: NULL
  provider_location: 278
      provider_auth: NULL
        snapshot_id: NULL
     volume_type_id: NULL
But When I attach volume to VM, It looks like abnormal.
This is my block_device_mapping db table.
mysql> select id,instance_id,volume_id,connection_info from block_device_mapping where deleted=0\G;
*************************** 1. row ***************************
    instance_id: 5
      volume_id: 25
connection_info: {"driver_volume_type": "iscsi", "data": {"device_path": "/dev/disk/by-path/ip-10.245.34.51:3260-iscsi-iqn.1992-08.com.netapp:sn.1574419210-lun-0", "target_discovered": false, "target_iqn": "iqn.1992-08.com.netapp:sn.1574419210", "target_portal": "10.245.34.51:3260", "volume_id": 25, "target_lun": "0"}}
*************************** 2. row ***************************
    instance_id: 5
      volume_id: 26
connection_info: {"driver_volume_type": "iscsi", "data": {"device_path": "/dev/disk/by-path/ip-10.245.34.51:3260-iscsi-iqn.1992-08.com.netapp:sn.1574419210-lun-0", "target_discovered": false, "target_iqn": "iqn.1992-08.com.netapp:sn.1574419210", "target_portal": "10.245.34.51:3260", "volume_id": 26, "target_lun": "1"}}
*************************** 3. row ***************************
    instance_id: 5
      volume_id: 32
connection_info: {"driver_volume_type": "iscsi", "data": {"device_path": "/dev/disk/by-path/ip-10.245.34.51:3260-iscsi-iqn.1992-08.com.netapp:sn.1574419210-lun-0", "target_discovered": false, "target_iqn": "iqn.1992-08.com.netapp:sn.1574419210", "target_portal": "10.245.34.51:3260", "volume_id": 32, "target_lun": "2"}}
3 rows in set (0.00 sec)
You can see volume_id is different. BUT every device_path is same. So when I mount a volume in VM,  wrong volume mounted.
When I use HP san volume driver, every device_path is different. for example,
mysql> select id,instance_id,volume_id,connection_info from block_device_mapping where deleted=0 limit 3\G
    instance_id: 49
      volume_id: 57
connection_info: {"driver_volume_type": "iscsi", "data": {"device_path": "/dev/disk/by-path/ip-10.113.1.1:3260-iscsi-iqn.2003-10.com.lefthandnetworks:c1-z1-pek:292:volume-00000039-lun-0", "target_discovered": false, "target_iqn": "iqn.2003-10.com.lefthandnetworks:c1-z1-pek:292:volume-00000039", "target_portal": "10.113.1.1:3260", "volume_id": 57, "auth_password": "project_secret_P20120816-004", "auth_username": "proj_P20120816-004", "auth_method": "CHAP"}}
    instance_id: 93
      volume_id: 132
connection_info: {"driver_volume_type": "iscsi", "data": {"device_path": "/dev/disk/by-path/ip-10.113.1.1:3260-iscsi-iqn.2003-10.com.lefthandnetworks:c1-z1-pek:568:volume-00000084-lun-0", "target_discovered": false, "target_iqn": "iqn.2003-10.com.lefthandnetworks:c1-z1-pek:568:volume-00000084", "target_portal": "10.113.1.1:3260", "volume_id": 132, "auth_password": "project_secret_P20120821-002", "auth_username": "proj_P20120821-002", "auth_method": "CHAP"}}
    instance_id: 94
      volume_id: 133
connection_info: {"driver_volume_type": "iscsi", "data": {"device_path": "/dev/disk/by-path/ip-10.113.1.1:3260-iscsi-iqn.2003-10.com.lefthandnetworks:c1-z1-pek:571:volume-00000085-lun-0", "target_discovered": false, "target_iqn": "iqn.2003-10.com.lefthandnetworks:c1-z1-pek:571:volume-00000085", "target_portal": "10.113.1.1:3260", "volume_id": 133, "auth_password": "project_secret_P20120821-002", "auth_username": "proj_P20120821-002", "auth_method": "CHAP"}}
Why Netapp driver set device_path is same? Is this normal situation?
Please help me in understanding setup using netapp driver.
Thanks in advance.
1 REPLY 1
esker
Hi Jay,
It actually is relevant that your Nova version is Essex-1.  There were a few fixes / enhancements that our driver required that came fairly late in the Essex development cycle.  Could you 1) retry with latest Essex-stable and 2) also make use of the most recent version of the driver intended to be used w/ Essex here:
https://github.com/rushiagr/nova/tree/essexport/nova/volume
Thanks!
