Simulator Discussions
Data ONTAP Edge instead?
JANDREWARTHA
Now that Data ONTAP Edge is released, can we just use that instead of the simulator?
1 ACCEPTED SOLUTION
neric
Hi Jandrewartha,
You could probably use Edge if you wanted to test some basic functionality and become more familiar with the command set.  However, the simulator does try to mimic actual hardware as much as possible and as such gives a slightly different experience.  For instance you can create a multi-node C-mode cluster using the simulator.  You cannot do that with Edge.
Good Luck!
5 REPLIES 5
kuber
Technically I think you can run it as a Sim but the required for the hardware might be high-end. Check the
Interoperability Matrix
neric
Hi Jandrewartha,
Good Luck!
terryzolinski
I think the biggest trade-off other than a limited feature set is the fact that Edge is a paid product, whereas simulator is free to use. Edge requires a Snapvault Secondary, otherwise it shuts itself down after 72 hours, according to my SE.
Also there is no Snapmirror at this time with Edge. It's a source only product, so you could use it to replicate to a filer, but could replicate back. Ie, one-way replication.
JANDREWARTHA
I have evaluation keys from the VMworld promotion, although I don't know how long they're good for. Lack of SnapMirror is a big missing feature.
neric
Check out Stewart Vaughn's blog.  It contains lots of good information and links
http://virtualstorageguy.com/2012/09/06/data-ontap-edge-vsa-is-available-to-download/
