Simulator Discussions
Is ONTAP8.1.2 C-Mode simulator supported with System Manager 2.1?
andyl
Hello Team
I tried to add a 4-node simulator into System Manager, which is 8.1.2 + System Manager 2.1, but below is the error I'm seeing now:
It actually works perfectly for Sim 8.1.1 C-Mode, so I guess 8.1.2 might not be supported yet, so can you help me confirm this?
Thanks & Regards
Andy
3 REPLIES 3
karthikv
Hi Andy,
What error are you getting in System Manager 2.1? The error is not visible in your post.
Data ONTAP 8.1.2 Cluster-Mode is qualified on System Manager 2.1. Ideally Data ONTAP 8.1.2 Cluster-Mode simulator should also work with System Manager 2.1.
I am assuming that you might be getting some simulator specific error; but need to confirm
Regards,
Karthik
andyl
Thank you Karthik
Here is the error I'm seeing now:
Thanks
andyl
Hi Karthik
I think you are right, the failure is caused by the mismatched version string, I uninstalled System Manager 2.1 and went with 2.0R1, it works for C-Mode Simulator, so looks like the problem is on the System Manager.
Thanks
Andy
