Simulator Discussions
ONTAP Simulator 9.2 running on VirtualBox or RedHat Enterprise Virtualization
ClearSharkian1
Good day everyone!
A customer of mine is runnning VirtualBox and/or RedHat Enterprise Virtualization on his Mac and was wondering if there was any way to run the ONTAP 9.3 Simulator in either of those environments.  I know right on the Simulator download site that is only runs in a VMware environment but thought I would do my due dilligence and check here just in case.
Any thoughts/experiences would be greatly appreciated folks.
Thank you in advance.
Rob
2 REPLIES 2
AlexDawson
RHEV only seems to support Windows and Linux VMs, which ONTAP is not (it is close to FreeBSD), so I'm pretty confident it won't work.
asulliva
Hello Rob,
It is possible to run the Simulator using Oracle's VirtualBox. I don't think the Simulator is supported, but if it is this would certainly fall into the "unsupported" category : )
If you are a partner with access to FieldPortal, please send me an email (community username at netapp.com), I can send you a document to help.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
