Simulator Discussions
Ontap Simulator 8.1.1 and disk shelves
vongillus
Hi,
I just downloaded the latest SIM 8.1.1. It's written that it's possible to use in shelves disks of 9 GB maximum but it's not explained how to do it. I see that there is a virtual disk of 250 GB. I didn't found either the script "makedisks.main" to create such disks.
Any idea?
Thanks
1 ACCEPTED SOLUTION
tonacki
I just uploaded a document on how to add disks when using Data ONTAP 8.1.1 simulators.  The script name and location has changed, so try using the new instructions.  Let me know if you have any comments too.
Thanks, Tom
6 REPLIES 6
tonacki
Thanks, Tom
vongillus
It works as described, I can now play with the simulator!
Thanks a lot!
Gilles
scottgelb
Any way to get the 8.1.1 image tgz for the vsim? Then we can upgrade without having to recreate it when on the 8.1 already. Only internal NetApp get access to those images but would be really nice to have access to he full vsim or the upgrade tgz.
khorheesoo
anyone having problem downloading the 8.1 simulator? I tried just now. It just brings me to a page as the product is not found
tonacki
I just tried all 4 images for 8.1.0 and the files were found and started to download.  Can you refresh the page and try again?
Tom
scottgelb
worked for me too..but I would prefer the upgrade image file to upgrade my existing VSIMS (3x  7-mode, 4x cluster mode in two clusters) instead of recreating them to go from 8.1 to 8.1.1
