RPC: Remote system error
[ Edited ]
I just installed two the 8.1.1 C-Mode simulators on my PC (Windows 7 running VMware Player) and while they seem to "see" each other just fine (e.g. cluster ping-cluster produces the expected results), when I do some other commands (e.g. autosupport modify -support disable *) I am greeted with:
ckeith::> autosupport modify -support disable -node *
Warning: Unable to list entries on node ckeith-02. RPC: Remote system error -
         Connection refused
Error: There are no entries matching your query.
Not all commands fail, but I don't want to get too far into trying to play with this if something is wrong.  So, the real question is, is this expected?
