Simulator Discussions
Running ontap 8.1.2 Sim on ESXi 5.1 - fix
MichaelCade
hi all i thought i would share i what i have found out. here is a blog post of what i found etc. and the fix to allow the new 8.1.2 work on ESXi 5.1
http://www.vzilla.co.uk/vzilla-blog.html
3 REPLIES 3
shatfield
The problem is that the 2gb sparse disk format is no longer supported on ESXi 5.1 and beyond.
Theres the easy fix, and the hard fix.
Easy fix:  before first boot, delete and recreate the SIM disk VMDK on IDE 1:1.  Use this method if you are building a new sim from scratch.
Hard fix: re-enable 2gb sparse disk support, and convert the disk to a supported type with vmkfstools.  Use this method if you have an existing sim you are trying to get working after upgrading your esxi install.
For example:
  1. enable ssh and esxishell
  2. use ssh or DCUI to access esxi shell
  3. cd /vmfs/{datastore name}/{vsim folder}
  4. vmkload_mod multiextent
  5. vmkfstools -E DataONTAP-sim.vmdk DataONTAP-sim-2gbsparse.vmdk
  6. vmkfstools -i DataONTAP-sim-2gbsparse.vmdk -d thin DataONTAP-sim.vmdk
  7. vmkfstools -U DataONTAP-sim-2gbsparse.vmdk
  8. vmkload_mod -u multiextent
rbrinson
Can you give details of the original issue you experienced?  I went to you BLOG site but did not see any specifics.  Thanks.
shatfield
Essentially, the sims are packaged using a virtual disk format thats no longer support on esxi out of the box.
The blog post vanished a while ago, but its been discussed here before, for example:
https://communities.netapp.com/message/106708#106708
