Simulator Discussions
Simulate ONTAP issue-8.2
RAKESHBCA
Hello,
Can someone help out on the issue related with simulator ONTAP 8.2 available to download from this linkhttp://support.netapp.com/NOW/download/tools/simulator/ontap/8.X/ and the actual size of file is approx 300 MB but after downloading, the file shows 10 MB.
Kindly suggest.
kind regards,
Rakesh
3 REPLIES 3
RAKESHBCA
Hello,
did i ask the stupid query or there is no answer available. kind regards,Rakesh
venkat3
Hi Rakesh,
I am able to download the cmode simulator.It took me around 30mins approx (depends on the bandwidth and download speed)
I am not sure why the download is not working for you. May be the download is getting disconnected. Are you using any download managers ? or direct browser download.
I would suggest you to use the feedback link in the bottom of the page for http://support.netapp.com/NOW/download/tools/simulator/ontap/8.X/ to report download problems
-Srinivas
RAKESHBCA
Thanks Srinivas.
