Hi,
I am trying to make use of the variable referencing feature of SnapCreator to create a logfile name, and I am slowly coming to the conclusion that it is not as flexible as I had hoped it to be. I am using SC 3.6.0c.
It would appear to me that concatenating variables is only possible when using a dash "-" between the variable names. Any other character (I tried underscores "_" and dots ".") stops variable substitution.
I am running an executable as a POST_NTAP_DATA_TRANSFER_CMD and want to log any output from this exe to a logfile with a name like this "hksql4.SD.daily.out.20130115181730-qsm.log" under SC's logfile directory so that it can be picked up by SC's GUI. For this, I need to construct a string by using the following variables: %CONFNAME and %SNAP_TIME, but with ".out." between the two variables.
Is there any way to achieve this with any current versions of SC ? Maybe I am overlooking something, but this:
CUSTOMZERO=.out.
CUSTOMONE=%CONFNAME-%CUSTOMZERO
CUSTOMTWO=%CUSTOMONE-%SNAP_TIME-qsm.log
creates something very close, hksql4.SD.daily-.out.-20130115181730-qsm.log, but doesn't get picked up by the SC GUI report section because of the extra dashes in the logfile name.
Wouldn't it be nicer to reference variables via this construction %{VARIABLE_NAME} and allow more flexible parsing ?
(ps. for those of you who think I should just let my .exe print to stdout or stderr, and let SC's debug log pick up the output, I am confronted with an executable (perl2exe compiled perl script) that falls victim to this problem: http://support.microsoft.com/kb/971163 and a hotfix that is not working properly).
Thanks in advance,
Filip
