Data Backup and Recovery
Productized solution around OSC?
smithr
When do  we anticipate announcing fully supported products that have been integrated and tested with OSC?  Which NetApp products will actually connect, directly or through a lower-layer product -- Snap Creator Oracle Plug-in, SMO/SMSAP, OEM12c, SnapDrive, or anything else that talks to Data ONTAP?
1 ACCEPTED SOLUTION
nkarthik
currently OSC is community supported. it connects to Ontap using Direct ZAPI calls. it's not using SMO, SDU and OEM 12c to connect with Ontap. Please let me know, if you need any help.
Regards,
Karthikeyan.N
1 REPLY 1
nkarthik
Regards,
Karthikeyan.N
