Software Development Kit (SDK) and API Discussions
Certificate Based Authentication using NetApp SDK Python
NETAPP_USER_NAME
Getting the following error messages when attempting CBA to ONTAP 8.3.1 using Python SDK 5.2.2  (realize this is down level).  We have a signed CA cert and trust chain installed on the NetApp but it appears to be flagging it as a self-signed cert.
From host:
# python  apitest.py -C CERTFILE.pem <HOSTNAME> "system-node-get"
OUTPUT:  <results status="failed" reason="[Errno 1]] _ssl.c:### error: ########:SSL routines: SSL3_READ_BYTES:tlsv1 alert unknown ca" errno="13001"></results>
From NetApp apache_error.log:
[ssl:error] Certificate Verification: Error (19): self signed certificate in certificate chain [INFO FOR ROOT CA]
Any ideas why this is treating my CA issued cert as self signed?
Thanks,
Bill
1 REPLY 1
Nick-Elliott
are you including the ca certs?
    def set_ca_certs(self, ca_file):
        """ Specifies the certificates of the Certificate Authorities (CAs) that are
        trusted by this application and that will be used to verify the server certificate.
        self.ca_file = ca_file
