Software Development Kit (SDK) and API Discussions
Connection error to Storage System for my ClusterDataontapServer chose TLSv1,protocol notsupport
RATNA_GUDLAVALLETI
Hi ,
I am trying to connect my netapp cluster ontap device throght Netapp Management SDK, getting error that "Connection error to Storage System for server choose TLSv1,
but that protocol version is not enabled or not supported by the client.Is there any way get source code for Netapp SDK and edit it...to fix this issue.
Thanks for ur reply in advance.
-Ratna..
3 REPLIES 3
richard_payne
Which method are you using to connect to the filer? I've never seen that error...
--rdp
RATNA_GUDLAVALLETI
Thanks  richard payne,
this.runner = new ApiRunner(ApiTarget.builder().withHost(host).withUserName(admiUuser).withPassword(adminPasswd).withTargetType(TargetType.FILER).useProtocol(protocol).build());
Above method i am using get netapp 7 and C Mode devices and getting that error.
-ratna
teksreenath
I am also facing the same issue. Do we have any solution for this issue?.
