Software Development Kit (SDK) and API Discussions
FAS 2552 - monitor temperature with C#
sanremo
Hi
I plan to develope a small C# program to monitor temperatures as measured by chassis sensors.
I downloaded the SDK but it seems too complicated for me...
For now I can obtain the desired info by connecting through SSH (using SSH.NET library) and submitting the following command :
system node run -node local -command environment status chassis
The next step is to create a loop and execute the command every, let's say, 10 minutes: do you think this could become a performance problem for the 2552? I don't know the library details and i assume it flawless implement the SSH protocol (disconnetting properly for example), I hope not to kill my storage with this approach...
Here is my first functioning C# prototype:
static void Main(string[] args)
	using (var client = new SshClient("my2552_ip_address", "user", "password"))
		client.Connect();
		SshCommand command = client.RunCommand("system node run -node local -command environment status chassis");
		string result = command.Result;
		string s1 = result.Substring(result.IndexOf("Ambient Temp"));
		int index = s1.IndexOf(Environment.NewLine);
		s1 = s1.Substring(0, index);
		string[] token = System.Text.RegularExpressions.Regex.Split(s1, @"\s+");
		string state = token[2];
		string currentReading = token[3];
		Console.WriteLine("Temperatute status: " + state);
		Console.WriteLine("Temperatute current value (°C): " + currentReading);
		client.Disconnect();
Thank you!!
1 ACCEPTED SOLUTION
francoisbnc
Hi,
It's not necessary to use the .NET binding in the first step.
Just add netapp-manageability-sdk-5.6\lib\DotNet\ManageOntap.dll
add in your project:
using NetApp.Manage;
Next you have to deal with NaServer for connection/auth and NaElement Class.
For an example of , you can use
netapp-manageability-sdk-5.6\zedi\zexplore.jar
You can directly generate code from there
François
4 REPLIES 4
francoisbnc
Hi,
Without too much effort, you can have something running quickly.
Just add dll ManageOntap in project references.
Here is an zapi example:
using System;
using System.Collections.Generic;
using System.Text;
namespace ConsoleApp1
    class Program
            NaServer s = new NaServer("filer", 1, 0);
            s.ServerType = NaServer.SERVER_TYPE.FILER;
            s.TransportType = NaServer.TRANSPORT_TYPE.HTTPS;
            s.Port = 443;
            s.Style = NaServer.AUTH_STYLE.LOGIN_PASSWORD;
            s.SetAdminUser(@"user", "pass");
            NaElement api = new NaElement("environment-sensors-get-iter");
            NaElement xi = new NaElement("desired-attributes");
            api.AddChildElement(xi);
            NaElement xi1 = new NaElement("environment-sensors-info");
            xi.AddChildElement(xi1);
            xi1.AddNewChild("node-name", "<node-name>");
            xi1.AddNewChild("sensor-name", "<sensor-name>");
            xi1.AddNewChild("sensor-type", "<sensor-type>");
            xi1.AddNewChild("threshold-sensor-state", "<threshold-sensor-state>");
            xi1.AddNewChild("threshold-sensor-value", "<threshold-sensor-value>");
            xi1.AddNewChild("value-units", "<value-units>");
            NaElement xo = s.InvokeElem(api);
            NaElement results = xo.GetChildByName("attributes-list");
            System.Collections.IList resultslist = results.GetChildren();
            foreach (NaElement result in resultslist)
                Console.WriteLine(result.GetChildContent("node-name"));
                Console.WriteLine("{0}: {1}", result.GetChildContent("sensor-name"), result.GetChildContent("threshold-sensor-value"));
I don't think that coud be a performance problem, regarding of number of requests, in comparaison, Oncommand  Unified Manager make by minutes.
sanremo
Hi
thank you for the fast response
I'm very new to the Netapp sdk: I've downloaded the "netapp-manageability-sdk-5.6-dotnet-bindings" and I cannot find the dll you mentioned, I can only find "netapp-manage.dll"; could you provide a link to download the one you are speaking about or provide an example with the sdk I found?
Thank you!!
francoisbnc
Hi,
François
sanremo
Thank you François
now I can use the API you provided.
I developed a small windows service that queries the sensors, saves the temperature in a database and sends hi temperature alarm and daily report by emails.
Thank you for your valuable support
Bye
