Software Development Kit (SDK) and API Discussions
How to get NAA for lun or volume
HASMIK_HAYRAPETYAN
Hi,
I am looking for ways to get NAA identifier for NetApp volumes and luns using DFM Server API. Does DFM's API provide such functionality?
Thanks in advance for any help.
1 ACCEPTED SOLUTION
obrakmann
Arguably the easiest way to map from a LUN to the corresponding datastore is to use the VSC. That's manual though, no programming involved.
If you need a program or a script to do the mapping, Rick's answer already was correct:
A LUN's 'naa.' number IS its WWN, it's just another name.
To get the WWN, you use the serial-number of the LUN, convert it to its hexadecimal ASCII representation* and prefix it with "naa.60a98000". You can get the LUN serial-number using the 'lun-list-info' API call (to a filer, not to the DFM).
Hope that clears it up.
* So, a '1' is 0x31, an 'a' is 0x61 etc.
22 REPLIES 22
rle
NetApp Alumni
Hi Hasmik,
Are you looking for the LUN WWID or WWN?  If so, it is: made of 0x60a9800 + the hexadecimal equivalent of the LUN status.  The LUN status is returned from lun-list-info API.
Volume and LUNs have UUIDs but are available from ONTAP APIs.
Regards,
   - Rick -
obrakmann
Hi Rick,
what do you mean by "LUN status"?
Looking in the Ontap SDK documentation for the lun-list-info API call, I can see several fields that might apply: "device-id", which is a 32bit integer value (and optional, it didn't show up in my tests), "serial-number", which is a string, and "uuid", which is also a string.
Thanks in advance for clarifying.
Regards,
Oliver
obrakmann
OK, so I found the answer myself: it's the serial-number field.
rle
NetApp Alumni
Glad you found it.
   - Rick -
RAVI_PALADUGU
Please mark it answered if you got this resolved.
Thanks
Ravi
HASMIK_HAYRAPETYAN
Hi Rick,
Actually I am looking for ways to find mapping between VMFS datastore and NetApp lun(or volume). I am not sure that getting WWN or WWID of a lun can help me with finding it's corresponding datastore.
The information I have about the datastore is its name and naa.
I would appreciate if anyone could help me with that.
Thanks,
Hasmik
obrakmann
HASMIK_HAYRAPETYAN
Thank you very much guys, now it's clear for me what I am going to do
Thanks a lot!!!
HASMIK_HAYRAPETYAN
But look, I can get serial-number of the lun using ONTAPI, but I am using DFM API.
Using DFM API lun-list info retrurns two statuses - object-status, object-perf-status, but possible values for them are 'unknown', 'normal', 'information', etc...
So what to do with DFM API?
Regards,
Hasmik
obrakmann
With the DFM API, you have to use the 'lun-list-info-iter-start', '-next' and '-end' methods.  The -next method returns a 'lun-info' structure which has a 'lun-serial-number' field.
See the API docs at
HASMIK_HAYRAPETYAN
Thank you for your help.
I was looking for lun serial number in DFM Server API 4.0 documentations, that's why I didn't find it. Now I see it's present in later versions.
HASMIK_HAYRAPETYAN
That is wonderful, I just got the naa of a lun.
But what am I supposed to do with volumes? They don't have serial number.
Regards,
Hasmik
obrakmann
A volume has a UUID, though, which is its unique identifying feature.
To get from the LUN to the containing volume, you take the "volume-id" field from the same structure that has the LUN's serial number, and pass it to the "volume-list-iter-start" API call in its "object-name-or-id" parameter. The details are all in the API docs.
If you just need the name of the volume, that is also available from the structure returned by "lun-list-iter-next". The field is called "volume-name".
Which way you choose all depends on what you want to achieve in the end. Have fun and good luck!
HASMIK_HAYRAPETYAN
Thanks for your reply
What I need is to construct naa for volume too.
obrakmann
You've lost me at this point.  There is no such thing.
OPMANAGER
I had similar doubts on finding WWN of NetApp LUNs. I found the serial number of one my LUNs as nBK/R4qS/yL9nBK/R4qS/yL9 . Used a piece of java code to convert this to hexa as suggested here and got 6e424b2f523471532f794c396e424b2f523471532f794c39 as WWN. Is this right? Can someone confirm. Or should I remove the "/" in serial number before going for hexa conversion.
Regards,
Muthukumaran M.
HASMIK_HAYRAPETYAN
When I constructed naa for lun from it's serial number, I checked the result with naa that I got through VMware vSphere CLI. I used "esxcli storage core path list" command to get lun NAAs.
You also can check it this way, if you use VMware vSphere Command Line Interface.
HASMIK_HAYRAPETYAN
I see. Thanks a lot for your help
joelg
In case VSC is not installed you can use the following from linux box:
Original VMware device: naa.60a980002d643877753f426131466853
LUN sn: -d8wu?Ba1FhS
>echo  2d643877753f426131466853 | xxd -r -p
-d8wu?Ba1FhS%
________________________________________
Or Simply google for a hex to ascii converter.
Or if you're planning on converting regularly, you could add the following to your .barsh/.zshrch file:
naaconv () {
          echo "$*"|xxd -r -p
Which results on just having run the following:
> naaconv 2d643877753f426131466853
-d8wu?Ba1FhS%
mbeattie
Hi There,
For anyone looking for an example code of how to do this using the DataONTAP PowerShell Toolkit
(download the PowerShell toolkit from here: http://support.netapp.com/NOW/download/tools/powershell_toolkit/)
See example code below which contains functions to convert the LUN Serial number from Hex/ASCII to display the VMware NAA number.
Happy Coding.
Cheers Matt
Example Output:
PS C:\Scripts\PowerShell\Projects\GetLunInfo> .\GetLunInfo.ps1 -HostName "netapp1"
netapp1,/vol/vol1/luna,True,True,HnWOlJWxYNtV,naa.60a98000486e574f6c4a5778594e7456,1024,832,vmware,True
netapp1,/vol/vol2/lunb,True,True,HnWOlJWxYczq,naa.60a98000486e574f6c4a577859637a71,1024,992,vmware,True
netapp1,/vol/vol3/lunc,True,True,HnWOlJPRSzsu,naa.60a98000486e574f6c4a5052537a7375,250,233,vmware,True
'Script Name : GetLunInfo.ps1
'Author      : Matthew Beattie
'Email       : mbeattie@netapp.com
'Created     : 01/03/12
'Description : This script enumerates all luns and converts the LUN serial number
'            : to the VMware NAA Number.
'Functions Section
Param(
   [CmdletBinding()]
   [Parameter(Position=0,
      Mandatory=$True,
      ValueFromPipeLine=$True,
      ValueFromPipeLineByPropertyName=$True)]
   [String]$HostName
Function Get-HexToAscii{
   .SYNOPSIS
   This function converts a Hexadecimal string to ASCII string.
   .DESCRIPTION
   .PARAMETER
   Accepts an Hexadecimal string containing the value to be converted to ASCII
   .EXAMPLE
   Get-HexToAscii -hexValue "572d5850653463746b516870"
   [CmdletBinding()]
   Param(
         Mandatory=$True,
      [string]$hexValue
   $result = ""
   For($i = 1; $i -le $hexValue.Length; $i+=2){
      $result = $result + [convert]::ToInt16($hexValue.SubString(($i -1), 2), 16)
   Return $result;
}#End Function
Function Get-AsciiToHex{
   .SYNOPSIS
   This function converts an ASCII string to Hexadecimal string.
   .DESCRIPTION
   .PARAMETER
   Accepts an ASCII string containing the value to be converted to Hexadecimal
   .EXAMPLE
   Get-AsciiToHex -asciiValue "W-XPe4ctkQhp"
   [CmdletBinding()]
   Param(
         Mandatory=$True,
      [string]$asciiValue
   $hexValues = @()
   For($i = 1; $i -le $asciiValue.Length; $i++){
      $stringValue = $asciiValue.SubString(($i -1), 1)
      $hexValues  += "{0:X}" -f [byte][char]$stringValue
   Return [string]::join("", $hexValues).ToLower();
}#End Function
#'Initialization Section
Import-Module DataOnTap
$identifier = "naa.60a98000"
#'Connect to the controller.
Try{
   Connect-NaController -Name $hostName -ErrorAction Stop | Out-Null
}Catch{
   Write-Host "Failed connecting to $hostName"
   Break;
#'Enumerate all LUN's on the controller.
Try{
   $luns = Get-NaLun -ErrorAction Stop
}Catch{
   Write-Host "Failed Enumerating LUNs on $hostName"
   Break
#'Enumerate the Properties for Each LUN and convert the LUN serial to NAA number.
ForEach($lun In $luns){
   $lunPath   = $lun.Path
   $mapped    = $lun.Mapped
   $online    = $lun.Online
   $serial    = $lun.SerialNumber
   $naaNumber = $identifier + (Get-AsciiToHex -asciiValue $serial)
   $size      = [math]::truncate("{0:N0}" -f ($lun.Size     / (1024 * 1024 * 1024)))
   $sizeUsed  = [math]::truncate("{0:N0}" -f ($lun.SizeUsed / (1024 * 1024 * 1024)))
   $protocol  = $lun.Protocol
   $provision = $lun.Thin
   Write-Host "HostName,LunPath,Mapped,Online,Serial,NaaNumber,SizeGB,SizeUsedGB,Protocol,ThinProvisioned"
   Write-Host "$hostName,$lunPath,$mapped,$online,$serial,$naaNumber,$size,$sizeUsed,$protocol,$provision"
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
