Subscribe
How to retrieve and modify root volume options using api
I am trying to retrieve root volume (vol0) details using the api "volume-get-iter" and trying to set the snap reserve using the api "snapshot-set-reserve" but i am getting the below error. I am connected to the node vserver through tunneling.
Executing api call volume-get-iter tag  failed: "Unable to find API: volume-get-iter on node vserver
"Unable to find API: snapshot-set-reserve"
Am i doing anything wrong?
Re: How to retrieve and modify root volume options using api
Hello,
Have you tried on Zedi?
Try calling
system-api-list
Then check to see if the API you'd like to use is found.
