Software Development Kit (SDK) and API Discussions
Monitor disk scrubing with SDK
Epytir
Hello Community,
I use the https://github.com/willemdh/check_netapp_ontap script to monitor all our netapps.
This works fine in all versions we use (8.2.3 - 9.1).
On our new Netapp 2650 we got 5 disk "in scrubbing state". The scrubbing on the Netapp works fine and I already opened a case where netapp checked the FAS.
So I think this is a problem with the netapp 9.1 and the SDK. I know that the script not uses the newest verion of the SDK so I will Update it and test again.
Nevertheless I dont think that this is only related the the script because only 5 disks are in scrubbing state since 2 month and they are always the same.
Has someone here the same issues ?
I know this is not critical because it only affects the return from the scrubbing but if I cant fix this I must remove the disk scrubbing check from the script.
greetings
Epytir
0 REPLIES 0
