Software Development Kit (SDK) and API Discussions
Move volume in 7-mode
lb98
Can we move volume to a different aggregate in the 7-mode? I can see there areSDK  API to do iy. But looking at the System Manager console for volume, I do not see move action appeared for volumes?
Thanks!
3 REPLIES 3
asulliva
Volume move operations are a feature in clustered Data ONTAP.
7-mode you can snapmirror the volume from source aggregate to destination as a workaround, however this is not a non-disruptive operation.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
SeanHatfield
There was also a more limited vol move capability in the 7mode CLI.
https://library.netapp.com/ecmdocs/ECMP1368845/html/GUID-A03C1B1E-3DE2-455D-B5AD-89C1389EF0C8.html
From the requirements page, you can see it was more useful for SAN volumes.
https://library.netapp.com/ecmdocs/ECMP1368845/html/GUID-09E9890C-EFD4-47EA-9539-A658FD251C93.html
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
asulliva
I forgot about that!  It's been a bit since I used 7-mode : )
Thanks @SeanHatfield
