Subscribe
Need to set audit options for ontap 8.x cluster using java nmsdk5.3.1
[ Edited ]
Hi,
I need to set audit options for a cifs cluster(ontap 8.x) using java nmsdk5.3.1. I can't find the right APIs to do it.
Can someone help me regarding this.
Thanks in advance,
Sathyan
Re: Need to set audit options for ontap 8.x cluster using java nmsdk5.3.1
Sathyan -
Is it the fileservice-audit in a cifs vserver context family of APIs you're looking for ?
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff, Sr.
Independent NetApp Consultant http://www.linkedin.com/in/eugenekashpureff
Senior NetApp Instructor, IT Learning Solutions http://sg.itls.asia/netapp
(P.S. I appreciate 'kudos' on any helpful posts.)
Yes, I am looking for file auditing related APIs.
I need to set tthe below options using Java code,
             vserver audit create -vserver cifs -destination /my_audit_log -rotate-size 200MB -rotate-limit 5
and also need to read the logs.
Could you please help me in doing this.
