Software Development Kit (SDK) and API Discussions
Perl and Manageability SDK v9.3 apitest.pl issue
pete_veenbaas
Greetings - Just started playing with the Neatpp ManageabilitySDK and Perl.
I tried a simple use case of the apitest.pl smple program and am running into the following issue:
[root@svlv6231# pwd
/opt/netapp-manageability-sdk-9.3/src/sample/Data_ONTAP/Perl
root@centosvm# perl apitest.pl cluster01 foo bar system-get-version
Can't locate object method "new" via package "HTTP::Request" (perhaps you forgot to load "HTTP::Request"?) at ../../../../lib/perl/NetApp/NaServer.pm line 722.
Anyone have any idea what this error message means. It appears I have all the required Perl Modules loaded at run time.
Thx in advance!
1 ACCEPTED SOLUTION
asulliva
Hello @pete_veenbaas,
Which dependencies did you install?  When I use the Perl module(s) I install these:
  • LWP::UserAgent
  • XML::Parser
  • Net::SSLeay
  • Socket
  • Switch
LWP::UserAgent installs, among other things, the HTTP::Request module.
Also, you can see how to create a container based version of the NMSDK here if you're interested.
Hope that helps.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
asulliva
  • LWP::UserAgent
  • XML::Parser
  • Net::SSLeay
  • Socket
  • Switch
Hope that helps.
Andrew
pete_veenbaas
Thx Andrew - I was missing the LWP::Useragent module
