Subscribe
Accepted Solution
PowerShell module with cDot and Fpolicy
Hi,
I'm sure I posted this a few hours, if it turns up as a duplicate perhaps the mods can remove it.
Anyway, I'm looking for the cmdlets to manage Fpolicy in cDOT. I've found the cmdlets for 7-mode, but there doesn't seem to be any exact counterpart for the Nc-* ones.
I looked under Nc-Vserver, but nothing obvious. Could someone point me in the right direction?
Re: PowerShell module with cDot and Fpolicy
Hello @ChannelTapeFibre,
There are a number of cmdlets for managing Fpolicies with ONTAP.  You can view all of them using the Get-Command cmdlet:
Get-Command -Module DataONTAP | ?{ $_.Name -match "NcFpolicy" }
CommandType     Name                                               Version    Source
Cmdlet          Connect-NcFpolicyServer                            4.0.0      dataontap
Cmdlet          Disable-NcFpolicyPolicy                            4.0.0      dataontap
Cmdlet          Disconnect-NcFpolicyServer                         4.0.0      dataontap
Cmdlet          Enable-NcFpolicyPolicy                             4.0.0      dataontap
Cmdlet          Get-NcFpolicyEvent                                 4.0.0      dataontap
Cmdlet          Get-NcFpolicyExternalEngine                        4.0.0      dataontap
Cmdlet          Get-NcFpolicyPassthroughReadConnection             4.0.0      dataontap
Cmdlet          Get-NcFpolicyPolicy                                4.0.0      dataontap
Cmdlet          Get-NcFpolicyScope                                 4.0.0      dataontap
Cmdlet          Get-NcFpolicyServerStatus                          4.0.0      dataontap
Cmdlet          Get-NcFpolicyStatus                                4.0.0      dataontap
Cmdlet          New-NcFpolicyEvent                                 4.0.0      dataontap
Cmdlet          New-NcFpolicyExternalEngine                        4.0.0      dataontap
Cmdlet          New-NcFpolicyPolicy                                4.0.0      dataontap
Cmdlet          New-NcFpolicyScope                                 4.0.0      dataontap
Cmdlet          Remove-NcFpolicyEvent                              4.0.0      dataontap
Cmdlet          Remove-NcFpolicyExternalEngine                     4.0.0      dataontap
Cmdlet          Remove-NcFpolicyPolicy                             4.0.0      dataontap
Cmdlet          Remove-NcFpolicyScope                              4.0.0      dataontap
Cmdlet          Set-NcFpolicyEvent                                 4.0.0      dataontap
Cmdlet          Set-NcFpolicyExternalEngine                        4.0.0      dataontap
Cmdlet          Set-NcFpolicyPolicy                                4.0.0      dataontap
Cmdlet          Set-NcFpolicyScope                                 4.0.0      dataontap
Alternatively, you can use the Get-NcCommand cmdlet from the PSTK:
Get-NcCommand -Category FPolicy | Format-Table -AutoSize
Hope that helps.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Thanks for the help, but I'm still struggling:
PS C:\> Get-NcFpolicyStatus
Get-NcFpolicyStatus : The 'Get-NcFpolicyStatus' command was found in the module 'DataONTAP', but the module could not b
e loaded. For more information, run 'Import-Module DataONTAP'.
At line:1 char:2
+ Get-NcFpolicyStatus
+ CategoryInfo : ObjectNotFound: (Get-NcFpolicyStatus:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CouldNotAutoloadMatchingModule
PS C:\> Get-Command -Module DataONTAP | ?{ $_.Name -match "NcFpolicy" }
PS C:\> Get-NcCommand -Category FPolicy | Format-Table -AutoSize
Nothing is returned.
PS C:\> get-help Get-NcFpolicyStatus
get-help : Get-Help could not find Get-NcFpolicyStatus in a help file in this session. To download updated help topics
type: "Update-Help". To get help online, search for the help topic in the TechNet library at http://go.microsoft.com/fw
link/?LinkID=107116.
At line:1 char:1
+ get-help Get-NcFpolicyStatus
+ CategoryInfo : ResourceUnavailable: (Smiley Happy [Get-Help], HelpNotFoundException
+ FullyQualifiedErrorId : HelpNotFound,Microsoft.PowerShell.Commands.GetHelpCommand
PS C:\>
The first error message indicates there is something found around the cmdlet Get-NcFpolicyStatus, but not much more and there is no help entry.
Could there be a problem with my version of Ontap? I'm running 8.3.2, and in another thread I read something about certain QoS cmdlets no longer available after 8.2.
If appears there are some errors loading the module: "CouldNotAutoloadMatchingModule".  Are you able to load the module manually?
Also, what version of the PSTK are you using?  You can check using the "Get-NaToolkitVersion" cmdlet.
Andrew
A manual import seems to work, I at least don't get any error message. I should probably point out that I've successfully used other cmdlets in my setup, such as Get-NcVol, Get-NcVserver, Get-NcAggr and Get-NcSnapmirror. As such, I don't suspect I have a problem with importing the module.
PS C:\> Import-Module DataONTAP
(nothing is returned)
PS C:\> Get-NaToolkitVersion
Major Minor Build Revision
2 3 0 86
Ah, obviously. I was running an older version of the module. It would appear that eventhough I downloaded the latest version of the PowerShell toolkit, an older version was installed and the new install did not upgrade the version. I removed the module folder manually, and reran the installer.
New results:
4 0 0 231
Thanks for nudging me in the right direction.
To summarize; newer installs of the toolkit may not always upgrade existing installs.
That behavior is/was a result of the switch to the single "unified" toolkit deployer...where both ONTAP and E-Series modules were packaged together in a single installer.
Glad you were able to get it straightened out!
Andrew
