Software Development Kit (SDK) and API Discussions
Python API - NaElement crypt/decrypt child string problem
pilkar
Hi,
I would like to ask for an advice, why I'm getting an error when using methods child_add_string_enc() in NaElement object in python (v.2.6.6. Oracle Linux 6.7):
 Traceback (most recent call last):
  File "crypt_test.py", line 7, in <module>
    x.child_add_string_encrypted("crypt-pwd", passwd)
  File "NaElement.py", line 270, in child_add_string_encrypted
    encrypted_value = self.RC4(key,value)
  File "NaElement.py", line 365, in RC4
    box = self.prepare_key(key)
  File "NaElement.py", line 402, in prepare_key
    k = unpack('C*',key)
struct.error: bad char in struct format
ok then, I have added "import struct" in the NaElement.py file, then got this error:
  File "crypt_test.py", line 8, in <module>
Here is my test python code:
from NaElement import *
import struct
passwd = "Test-string-to-encrypt"
x = NaElement("test")
x.child_add(NaElement("plain-pwd", passwd))
What is the problem? Python v.2.6.6 should be supported, do I need any special packages to install? Quite the same code in Perl (using perl APIs with pack/unpack functions) works withould problems...
Thanks for any help in advance.
Rostislav
0 REPLIES 0
