Python HTTPS connection
I am having some issues to work with the python API to connect to the controllers. So far I was connecting using a cluster account. I am using Python 3.4 on a CENTOS 7.2 server using 5.4P1 MNSDK.
While opening a HTTPS connection I get:
Traceback (most recent call last):
File "", line 304, in <module>
File "", line 275, in GetSnapshotsList
raise StorageException("query failed: reason %s error number: %s ", resp.results_reason(),resp.results_errno())
__main__.StorageException: ('query failed: reason %s error number: %s ', '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)', 13001)
On the controllers I have a self-signed certificate. This error is despite I dont want to do an host or server verification: NaServer methods:
def is_server_cert_verification_enabled(self):
def is_hostname_verification_enabled(self):
return false.
I have solved the first problem adding the selfsigned certificate to my CA chain.
Now I try to connect to the vserver management IP, and I get:
File "", line 306, in <module>
File "", line 274, in GetSnapshotsList
resp=self.server_zapi.invoke("snapshot-list-info", "volume", self.volume["name"])
File "/ORA/dbs01/work/storage-api/lib/python/NetApp/", line 542, in invoke
return self.invoke_elem(xi)
File "/ORA/dbs01/work/storage-api/lib/python/NetApp/", line 482, in invoke_elem
File "/usr/lib64/python3.4/http/", line 1084, in endheaders
File "/usr/lib64/python3.4/http/", line 922, in _send_output
File "/usr/lib64/python3.4/http/", line 857, in send
File "/usr/lib64/python3.4/http/", line 1231, in connect
File "/usr/lib64/python3.4/", line 365, in wrap_socket
File "/usr/lib64/python3.4/", line 583, in __init__
File "/usr/lib64/python3.4/", line 818, in do_handshake
match_hostname(self.getpeercert(), self.server_hostname)
File "/usr/lib64/python3.4/", line 289, in match_hostname
% (hostname, dnsnames[0]))
ssl.CertificateError: hostname '' doesn't match 'vs2sx50'
Again I dont want to do any SSL verification. Is no otherway that to create a certificate (and DNS entry) with the vs2sx50 (this is my vserver name) on it?
Thank you.
Re: Python HTTPS connection
Have you tried
import ssl
ssl._create_default_https_context = ssl._create_unverified_context
to disable certificate verification?
Thank you! Indeed this solves the issue.
