Software Development Kit (SDK) and API Discussions
Re: Using 5.1 NM SDK with Certificate based authentication against cluster mode 8.2
Nick-Elliott
I'm stuck with an auth failure on simulator 9.3 when attempting to do cert based authentication using the SDK.
I used https://netapp.io/2016/11/08/certificate-based-authentication-netapp-manageability-sdk-ontap/ as a guide.
LAB93::> security login show -user-or-group-name cert_user
Vserver: LAB93
        Second
User/Group                 Authentication                 Acct   Authentication
Name           Application Method        Role Name        Locked Method
cert_user      ontapi      cert          admin            -      none
LAB93::> security certificate show -vserver LAB93 -type client-ca               Vserver    Serial Number   Common Name                            Type
LAB93      D47D7F0D6DDF7F10
                           cert_user                              client-ca
    Certificate Authority: cert_user
          Expiration Date: Tue Apr 20 18:39:15 2021
python apitest.py -C test.pem -K test.key 10.10.1.100 system-get-version
OUTPUT:
<results status="failed" reason="Authorization failed" errno="13002"></results>
1 ACCEPTED SOLUTION
Nick-Elliott
SSL Client Auth enabled got flipped back to false on me.  Flipped back to true and all is right with the world again.
1 REPLY 1
Nick-Elliott
