Software Development Kit (SDK) and API Discussions
Replacement for volume counters?
btoneill
On 8.3 it says the volume object is going to be deprecated and removed in a future release. The catalog "replaced-by" field is empty. What is going to replace this? Is there an ETA on it's removal?
Thanks,
Brian
3 REPLIES 3
richard_payne
Brian, where did you read this?
--rdp
btoneill
From the description in the catalog.
::*> statistics catalog object show -describe -object volume
Object: volume
Privilege: admin
Is Aggregated: false
Description: Note: This object is deprecated and will be removed in a
future release. CM object for exporting volume performance
counters
akitsen
Did you ever get a reply or find out what the volume performance counters were replaced with ?
Seems like this was swept under our feet without much warning...
